I have compiled the below program for run clogin script to login to router.
however im unable to pass the input from the command variable to the clogin string.
the string value on the command will contain spaces, eg : show version
any help appreciated
import os
import subprocess
hostname = raw_input("Enterlink name: ")
command = raw_input ("Enter command: ")
cmd = "clogin -c '{command}' " + hostname
subprocess.call(cmd, shell=True)
the output is as follows :
XXX#
XXX#terminal length 0
XXX#terminal width 132
XXX#{command}
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
XXX#exit
Connection closed by foreign host.
import os
import subprocess
XXX#
XXX#{command}
XXX#exit
