PVC solvents and THHN wire insulation
Secan
Joined Sep 20, 2024
205
Usually when you put wires in a house. You need to connect the empty PVC pipe first then pull the wires. I need to put AWG 1 wire and using 1.5" PVC pipe. There are some corners where I need to insert the wires then put PVC cement to connect the pipes. What if some PVC solvent drops fall into the wires insulation? A THHN wire has nylon outside coating. Can the nylon prevent the cement to melt the inner PVC insulation of the THHN wire?
