Audioguru again
- Joined Oct 21, 2019
- 6,826
Speakerphones long ago or very cheap ones used a press-to-talk button that disconnected the speaker to avoid acoustical howling feedback sounds. Newer speakerphones from about 30 years ago used an electronic switch that disconnected the speaker when there is a sound in the microphone and disconnected the mic when there was a sound in the speaker which your circuit uses. Recent speakerphones from 20 years ago use a "echo-canceller IC" that makes a model of acoustical feedback in the speakerphone and all the sound reflections in the room then it cancels the sounds.
You made a rubbing noise that cutoff the speaker's pulsing sounds. I think the pulsing sounds are made by the speaker's amplifier or its power supply from a phone line that is too long. Reducing the microphone gain will not fix the pulsing sounds.
