im trying to impliment PWM control of a heating element using visual basic, but have come unstuck. i cannot find ANYTHING on the net about it. would anyone have any kind of source code that i could use?
You may have a hard time with VB. It does not have those nice old PEEK and POKE functions that allow low-level hardware access. It will take a different language like Power Basic or X Basic, or else in-line assembler to let you do PWM.
If your frequency is low enough, you can buy or build one of the PC oscilloscopes. If your frequency is to high for that, you might have to get creative with your serial port and software other than VB.
You could get VB to generate PWM - since you are driving a heating element then the TIMER activeX control could output a waveform that is high and low, say over 1/10th of a second. You set the interval of the timer to the number of milliseconds you want - it is probably only accurate to a millisecond (I think there is a way of getting more accuracy).
Certainly when I use the timer in animation I do not notice any "Jerkiness"
Presumably for your project you need to sense temperature and output an on-off signal. The input and output will be harder than getting PWM. Sounds like you could use the parallel port for that... any more details?
