Hi everyone: I have been designing a circuit that will output a very low level pulse. The pulse train is two pulses, with each pulse at 10 mV for 50 uSec, and -10V for 50 uSec. This is repeated every milliSec. The outpus needs to be isolated, which (at least in my current attempts) has employed a transformer. I have all the drive and controls worked out and prototyped. I can't seem to get a good pulse across the transformer. The circuit runs off a single AAA alkaline cell with a boost controller to produce 3.3V. If everything works, I may reduce that to about 2V.
Can some one suggest a way to get to a solution?
Thanks in advance.
Thanks in advance.
