- Joined Jan 23, 2018
- 28,488
The points of the post were that first, it is not a circuit issue, but rather somehow an implementation issue. That means that if the circuit as built does not work, that it is somehow not the same as the presented circuit,while if it does not function perfectly, there are a number of normal variations in real world construction that will certainly cause variations in performance. I admit that I did not directly state thatthe TS should check for errors in construction or failed components.Bill,
I am fully aware of the limitations of the simulation,
The TS states his circuit does NOT WORK, I am trying to help him understand why .!
He is also aware he cannot have a zero Vout.
What is the point of your post?
The comment about the second supply voltage was a means of allowing the output to be set to zero when the sensed temperature was zero. That was in response to the comment that a zero voltage output could not be achieved with the circuit and components used. It is a method that I have used in the past, although it was with PT RTD device interface circuits that were more complex. It was a common scheme at the time, it works well.
