PSU ITX
bibble235
Joined May 29, 2018
65
Live in NZ with 240v electric and need to buy a PSU board for my motherboard. The current board is a IP-V120DD and the power supply is a toshiba 7041 with 6.32a and 120w. Looking on the internet the options for buying a new one was 200w
https://www.amazon.com/GOMMER-Switch-Mining-Supply-Replacement/dp/B09PVMFZZK
I want to understand the relationship between amp/volts/watts but also want to understand if this is the right thing to buy and the right power supply.
Thanks all.
34,810
Any electronic device should specify the voltage and current requirements of the device.
Power requirement is calculated by multiplying current and voltage.
P = I x V
where,
P = power in watts
I = current in amps
V = voltage in volts
For example, if the device requires 8A @ 12VDC, power requirement is 8A x 12V = 96W.
One would select a PSU (power supply unit) that is rated at least 20% higher power in order to provide some overhead. Hence in this example a PSU rated at 10A @ 12VDC = 120W would be well suited for this application.
34,810
Answer this question first.
What are the requirements of the load?
In other words, how many volts and amps does the computer require?
bibble235
Joined May 29, 2018
65
It is a standard ATX motherboard Gigabyte (GA-H87N-WIFI) with a 24 pin connector. In the manual it recommends a 500W power supply however it was housed in a BQ656S which has an internal DC-DC Inverter Board (IP-V120DD) which has the following spec 120W, 7A, 12V
This is the part which is broken and what I would like to replace.
Link to case: https://www.in-win.com/uploads/Product/computer-chassis/bq_series/BQ_Series_eDM.pdf
