Propeller from a model airplane...
Externet
Joined Nov 29, 2005
2,668
Hi.
A model airplane (that flies) has an ~8 inch propeller. It is meant to spin at a specific direction.
One side is subject to cavitation or suction, the other under pushing pressure to produce a flow force.
Its sides have different curvatures, almost flat or concave on its pressure side; convex on its suction side.
Usually the leading edges are blunt, the trailing edges are sharper.
If that propeller is put to use as a windmill; which of its surfaces should face the incoming wind ?
