Projects ideas with sensors
fullanitox
Joined Nov 11, 2018
Hello, I need ideas to carry out projects with sensors, but the application is not standard, an example of standard application is: if I need to measure the temperature, I buy a temperature sensor. That is, a standard application has such an extended application. I want to challenge myself. Thanks.
fullanitox
Joined Nov 11, 2018
The application would be to measure something for which there isn't sensor for that application or just is possible with a combination of various sensors. An example could be measure the wear of wheel.
danadak
Joined Mar 10, 2018
4,057
PID loop with accelerometers and optical/hall effect sensors suspending
a ball between two electromagnets.
Regards, Dana.
35,245
You can provide tire wear indicator by embedding markers in the tire thread.
For other examples, there are tire pressure sensors, and brake pad wear sensors.
Can you give us YOUR real application?
Picbuster
Joined Dec 2, 2013
1,062
Obtain vibration pattern and compare it with the vibration when new.
Picbuster
