Greetings,
Recently, I had been trying to build an Arduino temperature reader using a DS18B20 and display the output on 4x Seven Segment Displays. With a lot of trial and error (mostly errors), this was completed. This project was set up using an Arduino Nano driving a single multiplexed 74HC595 to drive the displays. It is capable of reading the full range of the DS18B20 (-55°C to +125°C (-67°F to +257°F)). The code is currently set up to read Fahrenheit degrees but can easily be changed to read Celsius. It has been tested on its low end with an inverted can of keyboard duster to -48.0F to its high end with boiling water to ~210.0F. I had no intention of displaying an F or a C in the display since I knew which temperature it was being used for otherwise, I'd have to add a 5th digit.
This was built using a breadboard. Granted, it would have looked better with less wiring using a single 4 digit display. The 4 individual digits were wired for the same purpose as this is what I had on hand.
Below is the schematic:
The schematic was made with gSchem which is part of the gEDA suite
Below is the zip file containing the schematic including the custom symbols that need to be installed for the schematic:
This can be used later if a PCB is to be designed out of it.
View attachment Arduino_DS18B20_temperature_reader-Schematic.zip
The following parts for this build are required:
Parts list:
1x Arduino Nano
1x 75HC595 8bit shift register - 16 pin DIP IC
1x 4.7k ohm 1/4 watt resistor
1x DS18B20 Maxim/Dallas temperature IC (can come in TO-92 case or prebuilt into a sealed cable assembly)
8x 330 ohm 1/8 watt resistors
4x 5011 Common Anode 7 segment LED display*
* You can also use a 4 digit 7 segment display module to connect to the 74HC595. It will save you a LOT of tedious breadboard wiring.
I wanted to build this as a basic starting platform for other projects such as a deep freezer controller with LED readout. The use of the single 74HC595 rendered the Arduino with free pins to work with control relays, etc. The readout is formatted to display numbers without leading zeros and to the tenth's decimal place. The code involved was taken from http://www.pial.net/arduino-controlling-a-4-digit-seven-segment-display/ and modified. The code uses the DallasTemperature and OneWire libraries. This code uses 5054 bytes (16% of program storage space).
Compiled with Arduino IDE 1.6.7
The OneWire.h and DallasTemperature.h library files are required and need to be installed to your Arduino IDE
The OneWire library home page is located at:
https://www.pjrc.com/teensy/td_libs_OneWire.html
Which will lead you to the OneWire GitHub page to retreive the latest version of the library at:
https://github.com/PaulStoffregen/OneWire
The OneWire library version used in this build is 2.3.3 and is pasted below:
View attachment OneWire-master.zip
The Maxim/Dallas home page is located at:
https://milesburton.com/Dallas_Temperature_Control_Library (Down at the time of this posting)
The needed Dallas temperature control library can be found here:
https://github.com/milesburton/Arduino-Temperature-Control-Library
The DallasTemperature control library version used in this build is 3.7.7 and is pasted below:
View attachment Arduino-Temperature-Control-Library-master.zip
The code is pasted below:
The code along with the needed libraries is contained in the zip file below:
View attachment Arduino_DS18B20_temperature_reader_code+libraries.zip
Many thanks to @ErnieM for your help in making this possible.
Parts list:
1x Arduino Nano
C:
* Modified with additions to original code 3/22/2017- Lawrence Hallman
* This code was taken and modified from the original code which can be found at:
* http://www.pial.net/arduino-controlling-a-4-digit-seven-segment-display/
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer;
const int ledPin = 13;// LED connected to digital pin 13
const int latchPin = 8;// Pin connected to ST_CP of 74HC595
const int clockPin = 9;// Pin connected to SH_CP of 74HC595
const int dataPin = 10;// Pin connected to DS of 74HC595
const int digitPins[4] = {
3,4,5,6}; //pins to control the 4 common anode pins of the display
const byte digit[12] = //seven segment digit bits + blank + minus
B00111111, //0
B00000110, //1
B01011011, //2
B01001111, //3
B01100110, //4
B01101101, //5
B01111101, //6
B00000111, //7
B01111111, //8
B01101111, //9
B00000000, //Blank
B01000000 //-
int digitBuffer[4] = {
1};
int digitScan = 0;
int soft_scaler = 0;
float tempC, tempF;
int tmp;
boolean sign = false;
void setup() {
TCCR2A = 0;
TCCR2B = (1<<CS21);
TIMSK2 = (1<<TOIE2);
TCNT2 = 0;
pinMode(ledPin, OUTPUT);
for(int i=0;i<4;i++)
pinMode(digitPins[i],OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
sensors.begin();
sensors.getAddress(insideThermometer, 0);
ISR(TIMER2_OVF_vect) {
soft_scaler++;
if(soft_scaler==15)
refreshDisplay();
soft_scaler = 0;
void refreshDisplay()
for(byte k=0;k<4;k++)
digitalWrite(digitPins[k], LOW);
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, B11111111);
digitalWrite(latchPin, HIGH);
delayMicroseconds(50);
digitalWrite(digitPins[digitScan], HIGH);
if(digitScan==1)
shiftOut(dataPin, clockPin, MSBFIRST, ~(digit[digitBuffer[digitScan]] | B10000000)); //inserting the dot
else
shiftOut(dataPin, clockPin, MSBFIRST, ~digit[digitBuffer[digitScan]]);
digitScan++;
if(digitScan>3) digitScan=0;
void loop()
digitalWrite(ledPin, HIGH);
sensors.requestTemperatures();
tempC = sensors.getTempC(insideThermometer);
tempF = DallasTemperature::toFahrenheit(tempC);
tmp = int(tempF*10);
if (tempF < 0){
sign = true;
tmp = abs(tmp);
else{
sign = false;
if (int(tmp)/1000 == 0){
digitBuffer[3] = 10;
if (sign){
digitBuffer[3] = 11;
else{
digitBuffer[3] = int(tmp)/1000;
if (int(tmp)/1000 == 0 && (int(tmp)%1000)/100 == 0) {
digitBuffer[2] = 10;
if (sign){
digitBuffer[2] = 11;
else{
digitBuffer[2] = (int(tmp)%1000)/100;
digitBuffer[1] = (int(tmp)%100)/10;
digitBuffer[0] = (int(tmp)%100)%10;
digitalWrite(ledPin, LOW);
delay(500);
