You do not need to know the value of R in this circuit. Since it is in parallel with a voltage source, it will not effect the value of the voltage Vx.How do I find the resistanceHow do I find the resistance R ??
I know this methodDepending on which source you examine each time, you have a different configuration.
Take a look here for an example: http://www.allaboutcircuits.com/vol_1/chpt_10/7.html
How??? Please solve the question to meYou do not need to know the value of R in this circuit. Since it is in parallel with a voltage source, it will not effect the value of the voltage Vx.
hgmjr
How??? Please solve the question to meYou do not need R.
Forget R.
You do not need R to solve this.
To find Vx, you only need to know the current flowing through the 5Ω resistor.How??? Please solve the question to me
okTo find Vx, you only need to know the current flowing through the 5Ω resistor.
R doesn't matter, as the voltage across R is 10V. That value is needed for the voltage on the left side of the top resistor.
Check out the links given above, giving you the answer to this question will not help you at all if the resistors change, or the current source and voltage source are switched around for the test.
The current through R WILL add to the total current being used by the circuit, but that current doesn't matter when calculating Vx (the current through the 5 Ohm).ok, but What is the current passing through the resistance 5??
Current in the resistance 5 of voltage source and current source , right??
And how I find??
They gave me the solution please my exam tomorrow
