Problem with Understanding 220VAC in a Fan Timer Circuit.
csg
Joined Sep 21, 2017
I want to build a ventilation fan timer circuit. Fan starts working when switch is closed and keeps working for a set time after it is open. SAB0529 has a circuit in its datasheet for this purpose which I'm going to build. However, I have no experience using 220VAC and I have some questions.
1. Where should I connect the Ground Line in this circuit. I know where 2 hot lines going to be connected but no idea about the ground line. There is no ground in the circuit diagram.
2. Vs is getting the voltage directly from the hot line and GND pin is not connected to the ground. I know value of the Vs pin is referenced to the GND pin but I can't understand how the IC works when the connections are like this.
3. After I understand the circuit I'm going to build it on PCB. What should I use for the voltage/output pins. For lower voltages I usually go with Jacks or soldering but I don't know if it is safe for higher voltages. I want to be as safe as possible.
Any help is appreciated. Thanks in advance.
bertus
Joined Apr 5, 2008
23,005
I have taken the schematic and enhanced some lines that where missing.
I also marked phase and neutral for you:
Bertus
JUNELER
Joined Jul 13, 2015
183
As per datasheet Vs is positive supply ,but not mentioned DC. But as per drawings Vs is getting a line Ac input(phase).
Its confusing the voltage to be supply. A little bit unsafe to do it.
csg
Joined Sep 21, 2017
Datasheet states direct operation from AC line is possible. However, as you mentioned I can't figure out how it is safe and how it is even working.
