hi Mr.Chip, do you mind to so me your connection diagram for max232cpe since im using cytron sk40c with pic16f887 and max232cpe rs232 but it's seems i have connection problem which i cant receive sms from my gsm module that is sim800
Welcome to AAC.
It is preferred that you do not restart old threads with new questions. I've given you your own thread.
The datasheet should answer most of your questions but if you need more help, Post a schematic of what you have so that members can help you.
https://www.maximintegrated.com/en/products/interface/transceivers/MAX232.html
Thread split from
http://forum.allaboutcircuits.com/threads/problem-with-max232.72263/#post-1064933
| Thread starter | Similar threads | Forum | Replies | Date |
Problem with Max232 - Data in the output is different from the input | Microcontrollers | 2 | |
Problem with max232 | General Electronics Chat | 18 | |
| P | problem with MAX232 output | Microcontrollers | 5 | |
| S | Problem with MAX232 | General Electronics Chat | 7 | |
| A | Problem with MAX232 capacitors value | Analog & Mixed-Signal Design | 1 |
