Problem with driving triac with phototransistor
daryooosh
Joined Jun 15, 2019
56
Hello
In following circuit:
The triac is always on (mcu = 0 and mcu = 5) but can not deliver sufficient power to the Load (Load is a 32 watt electromotor.)
How can i resolve the problem?
daryooosh
Joined Jun 15, 2019
56
Why not use a dedicated driver?
The MOC3043 would be fine to use.
See the datasheet for more info.
Bertus
Thanks, I'm familiar with mMOCxxxx devices but i was create the prototype PCB with TLP521-4 device which is 4 phototransistor in one IC.
LesJones
Joined Jan 8, 2017
4,544
Just looking at the datasheet for the T410 shows that it could require up to 10mA gate current to turn it on. Your 150 K series resistor will only give about 2 mA at the crest of the waveform (About 308 volts.)
For the photo transistor in the TLP521 to not provide any gate current is must be able to stand at least 308 volts between the collector and emitter. It is only rated at 55 volts.
Les.
daryooosh
Joined Jun 15, 2019
56
Les.
Do you mean that the logic of my circuit is correct and the only problem is that the correct elements are not selected?
LesJones
Joined Jan 8, 2017
4,544
You seem to have picked devices at random without checking that their specifications meet the requirements of your circuit and without doing any calculations.
Les
daryooosh
Joined Jun 15, 2019
56
Les
I were be aware of gate current but why is the gate current specified as a maximum in the datasheet? I thought I(gt) is the maximum value allowed and minimum allowable value is "guaranteed at 5% of I(gt) max" (as noted below of the table4 of datasheet).
panic mode
Joined Oct 10, 2011
5,308
you need to read the datasheet.
Table 1 at the very begin of the document shows range that Igt is 5-35mA for the product range (more than one product described)
Table 3 shows that absolute maximum gate current is 4A (max 20us)
Table 4 shows actual test conditions with Igt value of 10mA for T410. That is the recommended value for gate current for T410 as tests are used to prove that something works normally. if you want more sensitive device, choose T405 which can do the same thing with 5mA gate current.
daryooosh
Joined Jun 15, 2019
56
I read the T410 and many other datasheets. I noticed that in some cases the "Maximum Rank" tables show the worst cases rather than continuous operating parameters (like I(gt)-4A for 20 uS). But usually other tables have three columns called "Min", "Typ" and "Max" which show parameters related to continuous work.
However, I now know that Triac datasheets have their own definitions and standards.
Thanks for your help
DickCappels
Joined Aug 21, 2008
10,661
Turning on traics and SCRs slowly makes them susceptible to damage. You want a sharp transition from 0 V on the gate to more than the required trigger current. Triggering on the slope of a sine wave can work but is not a good idea. Notice that most lamp dimmer circuit you find on the internet (as below) use a daic to make a trigger pulse for the gate by dumping the charge in the timing capacitor (C1) into the gate with a very low rise time.
The MOC3043 uses an internal triac to dump a fasts risetime pulse into the gate. Not only that, but it has circuitry to make that the gate is only driven when the power line is near a zero crossing, thus reducing the stress on the triac and at times other circuitry compared to the case in which the traic can be switched on when the line voltage is high.
daryooosh
Joined Jun 15, 2019
56
Thanks for your great tip(Turning on traics and SCRs slowly makes them susceptible to damage.).
I found the your comment and attached documents useful to work with Triac. One of the documents describe the parameters added in Triac datasheets and another one have 10 golden tips to work with Triac.
DickCappels
Joined Aug 21, 2008
10,661
IGT or I(gt) is an indication of the sensitivity of the triac's gate threshold current. IGT (Max) would then be the maximum threshold voltage for the conditions specified, meaning that the actual threshold will not be higher than that.
I could not locate your attached document.
daryooosh
Joined Jun 15, 2019
56
yo
You can check it again.
However the original links are :
https://www.ween-semi.com/en/media/97/download?origin_nid=1651
and
https://class.ece.iastate.edu/ee330/miscHandouts/AN_GOLDEN_RULES.pdf
DickCappels
Joined Aug 21, 2008
10,661
From the application note to which you linked:
"Rule 1. To turn a thyristor (or triac) ON, a gate current
≥ IGT must be applied until the load current is
≥ IL. This condition must be met at the lowest
expected operating temperature."
This agrees with my statement in post #14
