Problem with digital electronic
dl324
Joined Mar 30, 2015
18,326
If he REALLY needs to do this asynchronously, I would recommend making a simple mod-12 ripple up counter and then decode the outputs to get the desired sequence.
He wants count down from 15 to 4, but that's what I did; on Friday. I did it with positive and negative clocked flip flops since he didn't say which he was supposed to use...
Beginner0001
Joined Sep 29, 2017
21
If I understand you correctly, the first group is for the current state and the second group is the next state?
If so, then you are saying that from State 15 you are going to go to State 4. Is that what you want?
Yes, you understood right.
Like is shown at table, first state is state 15, next is state 4, because i think that's how down counter works.
Beginner0001
Joined Sep 29, 2017
21
If I count down from three, wouldn't you expect me to go, "Three, two, one, GO!" or something similar?
Ok, i understan it now, i was confused probably because it starts with 15 and my profesor obisaly didn't explaind it very well.
What would a count down counter normally do when it counts down to it's minimum count?
The answer was given in an earlier post.
Counter will start from beginning. So after state 4 is state 15?
dl324
Joined Mar 30, 2015
18,326
Consult the datasheet for any counter and see what the typical behavior is. There are no commercial mod-12 counters because there isn't a general need, but there are many examples of decade and binary counters.
That's what I'd assume. If you have questions regarding expectations, you should ask your professor.
WBahn
Joined Mar 31, 2012
32,823
Unless told otherwise, that's about the only reasonable assumption to make.
