Problem when testing the AD620 amplifier with the function generator
Linupe
Joined Oct 24, 2022
6
Hello everyone, I have a problem testing the AD620 amplifier using a function generator.
I am injecting a 100mV sinusoid, and with the gain of a 1k resistor, which increases the signal 50 times. In this configuration I would have a 5v signal at the output, but I don't observe anything. What am I doing wrong? GND is common for the battery, function generator and oscilloscope. I'm using two 9v batteries to power the circuit. Follow my circuit.ad620_test.png
schmitt trigger
Joined Jul 12, 2010
2,229
What is the output’s DC level? Is it exactly zero, within a few milivolts from ground?
Why didn’t you build the circuit like the one on figure 48 of the datasheet?
Audioguru again
Joined Oct 21, 2019
6,826
The output cannot be "nothing". Instead it MUST have a DC output of about +7.7V, about -7.5V or about 0V.
What is the exact output DC voltage?
EDIT: What input frequency?
Linupe
Joined Oct 24, 2022
6
At the output I have around 35mV.
I tried connecting the circuit in figure 48 of the datasheet, as suggested, but I got no results, just a few millivolts at the output.
Linupe
Joined Oct 24, 2022
6
I get around 30mV at the output.
I'm injecting a 100mV sinusoid, with a frequency of 1kHz.
Linupe
Joined Oct 24, 2022
6
Hi Lin .
How is the signal generator connected?
E
Hi ericgibbs
I'm using a generator with two alligator type test leads, one red and one black. I'm connecting the red one to pin 3, and the black one to pin 2. The black tip of the generator is also connected to 0V. Is it correct?
ericgibbs
Joined Jan 29, 2010
21,569
Hi Lin,
That sounds OK.
We recently had a member who had a batch of 3 AD620 all fakes.
Connect a test circuit as though it is a LM741 pinout, check the output.
E
Linupe
Joined Oct 24, 2022
6
Hi Lin,
That sounds OK.
E
With the lm741 I got a signal at the output! My chips are probably having a problem then. Follow the measurement on the oscilloscope. For use as an instrumentation amplifier, which one can I use instead of the ad620? Thank you very much!
