Problem when measure square wave and Charge & Discharge
Sakamoto21
Joined Jan 20, 2023
9
Please help me, I got problem.
From circuit diagram
Target : I want to make square wave on Vout (Period =18 sec on :8 sec off: 10 sec)
I have problem when I use scope to measure triangle and Vout , I have followed target. But when I use scope to measure Vout only, time Period and time on reduce. it's not followed target.
I don't understand.
Q: why measure triangle signal and no measure, it's too difference.
* Actual I use op-amp: NJM2904C.
Simulate Vout
Period: 17.79 sec
on: 8.1 sec
Actual (No measure triangle)
Period : 16.67 sec
on 5.916 sec
Actual (measure triangle)
Period: 18.295 sec
on: 7.689 sec
***Actual is same sample and same parameter.o_O
Sakamoto21
Joined Jan 20, 2023
9
h S21.
This is what I see on LTS.
E
I have deleted the 1Sec Time step in .tran
I try make actual sample and measure on scope.
When I measure triangle point and Vout -> period,on time ,off time follow target.But
When I measure Vout only -> period,on time reduce.
Did you know cause that. I don't know why occur that
My Hypothesis :
1. I think about select op-amp ?
2. frequency on scope ?
ericgibbs
Joined Jan 29, 2010
21,601
Hi S21.
The scope probe of say 1meg or 10meg resistance on Triangle node loads that pin and causes a change in frequency.
Look at this sim.
E
ericgibbs
Joined Jan 29, 2010
21,601
He says,
This simple question is pretty clear to me.
IF he asks for alternative idea's, no problem, but let's try to answer his original query first,
E
