Many thanks. I have one for DM74LS123N, which I use.Just in case you don't have one, see the attached datasheet:
why so? not sure what you mean..If your looking to output a group of pulses clocked by a 0.2 Hz signal, the manner you connected the 74LS123 won't work. I think the 74LS123 would be overkill if that's your requirement.
Agh...circuit seems allright (according to the book) when generates millisec pulses, but in practice it fails to produce microsec pulses...any ideas, please!Onward to the second inquiry ... when you viewed the millisecond outputs, you only got one pulse per negative transistion of the 0.2 Hz signal. Your stated requirement was for a pulse group [multiple pulses] on negative transistion. This could be a miscommunication, but that's how I read your posting about the signals. If I misread, then your circuit is ok.
You may not have the scope set up to sample fast enough to catch short pulses. Try triggering the chip at faster rates, or modifying your scope sweep rate. The chip triggering capability does not diminish at slow rates.Well, now I have found out that chip starts working well and produces pulses of about hundred millisecond duration each with repetition time 5 sec, triggered by input pulse train. But it does not produce very short pulses, of duration few microseconds (with the same repetition time) - what I really need. When I change timing capacitor from 220microF to 0.0066microF it stops to produce pulses. Maybe any ideas? Any advice is very much welcome!
Well, it's easier for me to switch scope into microSec (or even nanoSec) range. However there are still no microSec pulses there (voltage does not change from low to high at all). Perhaps it is because some stray capacitance is present in the circuit which becomes larger than value of small timing capacitor. I guess, it might be a reason why my circuit does not produce microSec pulses. But how it could be fixed?You may not have the scope set up to sample fast enough to catch short pulses. Try triggering the chip at faster rates, or modifying your scope sweep rate. The chip triggering capability does not diminish at slow rates.
Yes, I had tried this but the result is similar to that when I change cap.Two suggestions:
1) varythe resistor instead of the cap.
It's Pico ADC-200, I think it's suitable for microsecond pulse observation.2) try the other side of the chip, or another chip.
And a question:
What is the bandwidth of your PicoScope? If you are using the 2202 or the ADC-212/3 then you can't measure microsecond pulses.
I took them at different time scales. Otherwise it could be impossible to see their shape distortions in detail.Peter,
Looking at your drawing tells me that as the pulse width gets shorter the sampling is not truely representing the output pulse.
1. I do not trigger scope with 0.2Hz.I have a few questions concerning your equipment setup.
1. Are you triggering the oscilloscope with the 0.2 Hz signal?
2. Are you triggering automatically with the oscilloscope or are you using internal?
3. If you are triggering internally, which slope and what is your trigger level?
It's 10 MHz.Two suggestions:
The ADC-2xx can either start collecting data immediately, or it can be programmed to wait for a trigger event to occur. The trigger event can occur when the channel A or B input crosses a threshold voltage, or on a change of state of the external (digital) trigger input. The trigger event can be either a rising or a falling edge.
The ADC-2xx can be programmed to place the trigger event at the beginning of the buffer, like an analogue scope, or at the end of the buffer (pre-trigger), or any point in between.
The external trigger input is the same as the signal generator output, so these two functions cannot be used at the same time.
