Problem using a 74190 bcd counter to count an object inside the room
vtc
Joined Apr 3, 2018
37
Hi all .
I am using 74190 bcd counter to count objects inside the room ..
I used two sensors on one gate, one of them to determine if the object in or out the room and the other to increment o decrement the counter.
The connection of the sensor with counter like this
If I set the counter up using sensor2 then by clocking the counter using sensor1 the counter count up also if I set it down it will count down ..
But when I tried to pass an object through the two sensor in or out the room the counter doesn't count as expected ..
The following video describe what I mean ^^
danadak
Joined Mar 10, 2018
4,057
This leads naturally to a state machine design.
As an object passes one sensor that sensor should enable the
other to either count up or down when the object continues on.
So if first sensor hit is outside room then it should enable count up,
if however first hit is inside room it should enable count down.
Now you have the additional problem of sensor spacing and an object
partially entering/exiting and changing its mind.
That would mean if second sensor not tripped in some time period
count is negated. One way of doing it.
Of course you have two objects side by side problem as well.
There are chips out here that implement state machines, counting, display
with a fairly simple GUI tool, but some additional learning would be required.
One way to start is to create a flow chart to test logical cases as discussed above.
Then the logic will fall out of the understanding.
Design can be done logic only, code only, or a mix of both.
Regards, Dana.
Kjeldgaard
Joined Apr 7, 2016
476
The video is a little hard to follow.
But try with a piece of cardboard or similar, about twice as wide as the distance between the two sensors, like simulation of a person.
Move this "person" quietly in and out of the "room".
vtc
Joined Apr 3, 2018
37
Regards, Dana.
I can't use code in this hw as my prof want .
He want the design using 74190 counter :(
I have tried.. still not work :(
vtc
Joined Apr 3, 2018
37
Can I use one sensor for counting up and the other for down using this counter as if I want to use 2 gates ?
Kjeldgaard
Joined Apr 7, 2016
476
I have been in doubt if we talk past each other, because I consider the task as a known quadrature detection of direction and distance?
You should get a set of signals as shown here:
I have drawn the sketch so I suppose the signal is high when the sensor sees a "person".
However, regardless of the active level, the counter should count up or down at a time, when a "person" has come completely past both sensors.
dl324
Joined Mar 30, 2015
18,478
Describe what the counter is doing and what you want it to do.
Show us a timing diagram for the signals you're generating for D/U# and clk.
danadak
Joined Mar 10, 2018
4,057
If you are counting objects/people passing in and out of a room you
need some form of state machine to address the problems discussed
earlier. That can be logic only and / or logic + CPU.
Just do a step by step "what happens" list when object enters or leaves,
then the logic will be intuitive. You have to fix prior discussed issues, even
what happens if object stops between sensors (clue a timeout), you need
to address that as well.
You have to decide is counter incremented when first sensor hit or object
passes both sensors. Just think about all the crazy things an object can
do if you want a complete solution. Then there is always multiple objects
staggered in time......arggh.....
Regards, Dana.
