I'm trying to simulate the behavior of a PMOS FET (BSH201) using the manufacturer's SPICE model. The datasheet states that the Idss (zero gate voltage drain current) is typically 50nA with Vds = -48V. However, when I run the simulation, the drain current is around 75uA (over 1000x times higher).
I also tried it with an IRLML6401 (at a lower voltage) and the drain current was also several orders of magnitude too high.
I'm running it with default settings in LTSPICE.
Any ideas what's causing this, or what I can do to solve it?
Many thanks
Many thanks
