problem of fourier series
bhuvanesh
Joined Aug 10, 2013
268
Choose the function f(t) ; −∞ < < +∞, for which a Fourier series cannot be defined.
(a) 3 sin(25t) (b) 4 cos(20t + 3) + 2 sin (10t)
(c) e-|t| sin(25t) (d) 1
fourier series are available for all periodic signal .its obvious that all the four are periodic.But somewhere i hear that fourier series is not possible for constant .could someone give me hint for the answer ,so try to come up. Thank you
bhuvanesh
Joined Aug 10, 2013
268
yes 1 is periodic with period infinity (or we can make period as we need and its extending from minus infinity to plus infinity )
bhuvanesh
Joined Aug 10, 2013
268
it should be periodic ,
it should finite discontinuous over one period
it should absolutely integrable over any period
it should not have no more that finite number of maxima and minima over single period
thats all i think
33,070
Where is this somewhere that you heard this?
Take the basic equation for x(t) in terms of it's Fourier series components and set all of them equal to zero except Ao (the coefficient of the cosine term at zero frequency) and what do you get?
But if they are being nitpicky, then ask yourself if a constant is absolutely integrable over one period.
33,070
thats all i think
Do you understand what each of these mean?
33,070
except this "it should not have no more that finite number of maxima and minima over single period"i know all
The simplest example would be a sine wave at an infinite frequency. In lay and imprecise terms, the problem is that such a waveform effectively becomes multivalued.
bhuvanesh
Joined Aug 10, 2013
268
no, it is not. Integrating constant over one period leads to infintiy. At the same time look my waveform for e-|t| sin(25t). There at infinite time signal amplitude leading infinite so it would not be periodic ,would't be?
33,070
Sketch that waveform and consider the effect of the dying exponential on the integral. Notice that it is important that the exponent be |t| and not just t. Why?
bhuvanesh
Joined Aug 10, 2013
268
x(t) = e^-|t|
Is this function absolutely integrable?
yes it integrable over -infinity to infinty .it gives zero
but it not integrable for x(t) = e^|t|,right?
If so, then any function y(t) for which |y(t)| <= |x(t)| must also be absolutely integrable. Why?
if x(t) is integrable ,sure then y(t) is integrable since y(t) is less than or equal to x(t).
x(t)= e-|t| sin(25t)
here how would you say |y(t)| <= |x(t).why it may not like |y(t)| => |x(t)?
33,070
How can if give zero?
Can you find any value of t for which e^-|t| is strictly positive?
Can you find any value of t for which e^-|t| is strictly negative?
If you can find one but not the other, then it can't integrate to zero.
bhuvanesh
Joined Aug 10, 2013
268
sorry i was doing wrong calculation
Because of magnitude we are going to have only e^-x ,where x= positive value for (minus infinity to plus infinty )
yes,its giving both positive and negative values,example e^ -1 it gives positive value but e^-10 gives negative value,but for any value its giving bounded value ,i mean its not giving infinity so its integrable,right?
if |x(t)| gives bounded value(not infinity ),then |y(t)| gives less than the bounded values of |x(t)|,right?
