problem in 3-input minority circuit.
mike9407
Joined Jan 4, 2016
3
1. Design a combinational logic circuit for 3-input minority circuit. Assume that a minority circuit is one which produces a HIGH (1) when two or more inputs are LOW (0).
Construct the logic diagram using AND-OR gate network, using only NAND gates and using only NOR gates (only report)
how to construct using AND and OR gate network and using NAND and NOr gates
JohnInTX
Joined Jun 26, 2012
4,787
Welcome to AAC.
Here you will find many people that will help you find problems with your work. What you will not find here is people who will do your homework for you.
Try to work out the problem, show your work then if you have specific questions post those questions along with what you have done so far.
mike9407
Joined Jan 4, 2016
3
Welcome to AAC.
i already tried out but still can't get it
RBR1317
Joined Nov 13, 2010
714
still can't get it
What did you not get? Did you have trouble creating the truth table? Were you able to minimize the Karnaugh map? Did you have trouble getting the AND-OR gate network from the K-map? Or did you not get the all-NAND or all-NOR circuit implementation?
