Problem identifying opamp pins
D2C
Joined Sep 24, 2025
Hi Everyone,
I recently made a 3 stage amplifier on dotted pcb with TLV9002 opamps. However the circuit didn't work. I have a doubt whether i made a currect connection with the opamp pin. I have provided the image of the opamp below.
The opamp has white line instead of dot notation. How to identity the pins (especially pin 1)? Does the line represent the top side of opamp with pin1 on the top left corner?
Thankyou
spenkmo
Joined Apr 24, 2025
40
There are only two possible orientations. As there are ESD diodes on all signal input and output pins (the other end of the diode connected to VCC or GND). You may try using a Ohm-meter to check the resistance between any signal pin to an unkown VCC-or-GND pin, in both directions. The two readings are different based on the ESD direction, and thus telling whether the unknown pin is VCC or GND.
sarahMCML
Joined May 11, 2019
703
Hi Everyone,
Thankyou
The chamfer on the left side in your image also denotes the low numbered pins, starting from pin 1 at the top left. See the bottom of the datasheet for the SOIC package outline.
du00000001
Joined Nov 10, 2020
200
TI uses/used a white line instead of some dot. (Others may have done the same, I just recently stumbled over a TI PCN notifying about a change from the white line to a pin 1 dot for some devices.) On SO* packages the white line is from pin 1 to the pin with the maximum number. Rasmussons' image shows the scheme for an 8-pin device correctly.
