PowerR
jismagic
Joined Sep 7, 2013
77
I want to make a power resistor network.
But i have two variables - resistor values,wattage.
I need to create any resistor values 0.1 to 20ohms and wattage ranging from 10W to 600W.
I was thinking of two options - 1. resistor network with all resistors with max wattage??
2. create a pool of resistors and then pick and use values/wattage when required.
Can you guys think of something better?
thanks
jis
Sparky49
Joined Jul 16, 2011
833
I've seen just a long length of enamelled copper wire being used to simulate a low R load. The middle is submerged in a bucket of water, of course, any part not submerged runs the risk of getting hot very quickly.
studiot
Joined Nov 9, 2007
4,998
The is a commonly recurrent question.
Have you done a forum search?
There are many factors to consider and your solutions depends upon what compromises you are prepared to make and what your personal resources allow.
How would you make a reliable connection to 0.1 ohms Where the connection resistance may be 0.3 ohms?
Some solutions form the past
http://forum.allaboutcircuits.com/showthread.php?t=95152&page=3
http://forum.allaboutcircuits.com/showthread.php?t=12372&highlight=load
see post 7 on this second one.
