I'm working on a project where I need a pinpoint source of bright white light that will be continuously on, so it needs to be plugged into a wall socket. I don't have any electrical knowledge, hopefully someone here can give me advice on the easiest/cheapest way to do this.
I see there are LED lights on ebay (such as this one: http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=180485485402#ht_2853wt_941)) and I have a few extra power adapters lying around. Can I just connect the power adapter to such an LED and plug it into the wall?
The LED lights I'm seeing have specs like this, but probably vary a lot:
3.5V~4.0V or 3.8~4.5V, etc
700mAh
3Watts
One adapter I have from an old cellphone has this output:
5.0V, 0.7A, no word on watts.
What would I need to do in order to power the LED light? Can I just attach the wires from the adapter to the contacts on the LED? If I'm thinking about this the wrong way, any advice is greatly appreciated.
Thank you!
Paul
700mAh
3Watts
Thank you!
Paul
