power supply with both ics tl494,lm339 .. #2
roberus
Joined Feb 18, 2021
38,946
The LM339's appears to be operating as an overvoltage detector that generates a PG 5V signal when an overvoltage is sensed.
Dodgydave
Joined Jun 22, 2012
11,395
The Lm339 is used to give the Power Good signal out , it checks when 12V supply is up and running.
The TL494 has built in op amp detection on pins 1,2 and 15,16 for Voltage and current sensing, so for extra protection to shut it down a positive pulse is applied to pin 4.
