power supply wiring Question
35,180
What is that instrument? Show us the full front panel.
You need a power supply to provide the three voltages specified.
35,180
Assuming that the +25V and -25V suppies are independent, connect the two BLACK and one GREEN terminals together.
Use the +6V supply adjusted for +5V.
Adjust the +25V supply for 7.5V.
Adjust the -25V supply for -2.5V.
MikeML
5,444
yeah thats what i did,only i put wire from GND into the COM port, results are as i wanted
Be aware that the Green post is connected to the building's earth (electrical panel) ground through the third prong of the power supply's AC Line cord.
You may or may not want to connect the circuit you are testing to the building's earth ground.
