The UF400x series is perhaps a bit marginal for the output diode for 1 A output. They are rated for 1 A but will run moderately hot and I'd be more concerned with adequacy of heat spreading foil on the PCB. There are many other ultrafast diodes available. There are UF versions of the 1N5400 series. I've never looked for 2 or 3 A rated ultrafast in surface mount. I would recommend staying with a Schottky if a suitable type could be found. I'm quite confident they exist, but I can't make a recommendation offhand.hi,
There is a high speed version of the 1N400x ie: UF400x.
E
