Power supply unit 24V 4A
ElectronicNewbie0
Joined Oct 18, 2025
54
Hello all,
I continued the schematic for my project, which a power supply unit, 24V 4A.
These are the stages i have designed:
Common Mode Emi filter ( i know its not needed, but i chose to do so in order to learn ) i took example from other designs and calculated the cutoff frequency.
Transformer + Bridge Rectifier, which gives at the collector of each transistor, unregulated 30V voltage.
the drivery circuit, made with the OP AMP , the output of the op amp, which i calculated it to be around 24.7V
then with the formula VO=VZ*(1+R1/R2), i calculated R1 and R2, having Vz= 5.6 V and VOUT = 24 V
I took example from other designs, and they usually put a RE , emitter resistor of low value, which i did in the schematic.
I know that overall the circuit has not a lot of protection, like no Tvs or so, but beside that, is the concept correct?
The way i designed and calculated the sizing is correct for each component?
Thanks all for the help ( consider that im a newbie yet.. )
35,299
The noise filters on the primary side are optional. What is not optional is a fuse which is not shown.
I don't know about the voltage regulation on the secondary side. I think that the op amp cannot supply enough drive to the pass transistors.
ElectronicNewbie0
Joined Oct 18, 2025
54
I will add them no problem :D.
U mean the current that the op amp can supply to the transistor bases? ( i chose worst case scenario, so i took the lowest Beta value )
ElectronicNewbie0
Joined Oct 18, 2025
54
U were right, its not sufficient, i have added a transistor before the 4 pass transistors, what do u think? i connected this correctly?
AnalogKid
Joined Aug 1, 2013
12,294
Power supply decoupling cap across U3.
Noise filter cap across D1.
It's ok to spread out the components to make the schematic a bit more readable. Electrons are cheap.
ak
ElectronicNewbie0
Joined Oct 18, 2025
54
ak
Hey,
Just a question, why D1 is a noise source?, its better to have a cap across D1 so voltage is more stable?
AnalogKid
Joined Aug 1, 2013
12,294
why D1 is a noise source? its better to have a cap across D1 so voltage is more stable?
A zener diode by itself cannot break into oscillation, one form of stability. A zener diode's reverse voltage does change with changes in temperature, another kind of stability.
Separate from that, reversed-biased diodes of just about any kind are known for being a noise source. Why? - Physics. That is why a reverse-biased transistor often is used as the core of white and pink noise generator circuits.
ak
ElectronicNewbie0
Joined Oct 18, 2025
54
ak
Oh i understood, It would be useful if im building a noise generator circuit to leave It without a capacitor, but this isnt the case :D
