Power supply from scratch question
A Homeschoolers Workbench
Joined Jul 26, 2016
142
I am building a power supply from scratch. I know how to do everything except, I do not know what size of a capacitor I need? what I want is for the dc to be able run chips
Thank you
38,506
The capacitor size depends upon the load current and the allowed ripple voltage.
Post a schematic of what you have so we can determine what you need.
SLK001
Joined Nov 29, 2011
1,549
The "chips" are fairly forgiving on their acceptable ripple values. Something in the neighborhood of 10,000μF would be a good starting point. Cruts is correct though, in his statement above. YOU decide what is an acceptable ripple voltage.
bertus
Joined Apr 5, 2008
22,923
Please upload the schematic to the forum using the "upload a file" button.
The site asks me to login.
SLK001
Joined Nov 29, 2011
1,549
100mV is a TON of ripple. Almost any capacitor will get you less than that.
And what is SO HARD about uploading a file?
SLK001
Joined Nov 29, 2011
1,549
Not for the output of a bridge rectifier as the op's schematic shows.
The typical ripple at that point is more like a volt or two under full load.
A link to a schematic is the equivalent to no schematic in my book. The OP is asking for advice - it is up to HIM to make sure all the information is presented in the question so that people he wants help from can have that information at their fingertips.
38,506
If you don't want to click on a link that's fine, but then I don't see the point of offering design advice when you don't know what the op is referring to. :rolleyes:
Joined Jul 26, 2016
142
Thanks for all the input,
the goals of my power supple are,
1 Learn
2 Keep it as simple as possible (This is why the schematic is very basic)
3 Make it to last
4 Make it inexpensive.
The reason I posted on this forum is to try to get a way to calculate how much ripple I will get for whatever amperage I draw.
Also it would be great is someone could tell me how much ripple is aloud for chips
Thanks
AIDayley
hp1729
Joined Nov 23, 2015
2,304
Thank you
Voltage regulation is good. What chips did you want to power? Voltage depends on the type of chips.
What parts do you have to work with for building a voltage regulator? Really basic? NPN and a Zener diode. LM78xx are actually cheaper, better and easier. Variable? LM317 or LM338 if you expect to use 3 Amps. You probably won't need 3 Amps unless you have specific design in mind.
Size of capacitor? Figure 1,000 microfarads per Amp of current as a general rule.
