That's just max voltage and amperage for rectifier I'd have to draw a schematic we will be running test on a more elaborate system I just need a good power supply to start from then once I get results most likely I think I will need to Automatically Adjustable Voltage As Per Amperage Because Water Supply Will ChangeHuh?
Where does 1600 Volts come from?
Please post a schematic or block diagram of your system.
Please don't plug it into the wall outlet.That's just max voltage and amperage for rectifier I'd have to draw a schematic we will be running test on a more elaborate system I just need a good power supply to start from then once I get results most likely I think I will need to Automatically Adjustable Voltage As Per Amperage Because Water Supply Will Change
I just need the capacitor size that will be able to handle 120v to 0 and 0 to 100 a I have a adjustable ac supply 120v going into a bridge rectifier going to be most likely 36 dc fuel cell will be completely enclosed in a insulated container with proficient protectionPlease don't plug it into the wall outlet.
No already did this my amp draw is from 5 amps to 9 amps at 36.7volts and water at a ph of 7.5 but my water conditions will change and my cell will be bigger and I will need my amps to stay the same so I can have the same out come this isn't for hydrogen productionIf you're purely in the experimental stage and you need 36VDC as your supply I would be tempted to use three cheap 12V lead acid batteries to get your 36VDC for you electrolytic cell. You can draw large currents from them and this will allow you to finish the cell design before committing to a potentially expensive power supply. Turning down mains voltage here in the UK would give us more power than a 120V supply and you'd still probably be limited to about 30A at 36V. I'm guessing your not sure what the current draw will be yet, is that right?
so my wattage because of water conditions will change so is there a capacitor for bridge rectifier that will compensate for the changes because I'm sure I will have to change my voltage to keep amperage the same because I need the same out come but don't know what level it will be until test have been doneNo already did this my amp draw is from 5 amps to 9 amps at 36.7volts and water at a ph of 7.5 but my water conditions will change and my cell will be bigger and I will need my amps to stay the same so I can have the same out come this isn't for hydrogen production
Okay, here is the deal.No already did this my amp draw is from 5 amps to 9 amps at 36.7volts and water at a ph of 7.5 but my water conditions will change and my cell will be bigger and I will need my amps to stay the same so I can have the same out come this isn't for hydrogen production
Sounds like the TS is trying to get around the HHO/Browns gas thing.You said "this isn't for hydrogen production".
Your thread title says you want a power supply for a hydrogen fuel cell, but why would you supply electrical power to a fuel cell, which is already a power supply for generating electricity.
In the US we have at our home 240v. At 200a.but I'm doing this at work where I have 480v.200a. If need don't think I'll required that though I won't know what my true wattage will be till its built but I can say it's for breaking bonds in the impurities in the waterOk so you're scaling up your design? I'm a little confused as to what supply you want for your scaled up design. Using directly rectified mains is dangerous as Ronv mentioned because it is not isolated. Your maximum power available on your load side cannot exceed the power available from your mains input. Here in the UK we can only realistically draw 3.12kW (240V*13A) so this is the MOST power we can have regardless of what we transform the voltage to, the current available will be indirectly proportionate to your voltage manipulation. That is in an ideal world with 100% efficiency and that world doesn't exist outside our minds, we always have losses.
He probably has the same style I have (grey tank on a nearby pole or big green box in the yard) that isolates him from his main utilities 7200 volt system.You can make me a believer with a photo of your transformer.![]()
Despite how some will squeal there is nothing illegal about running a high current load off of one leg of your homes 120/240 power system if it was built to work as a true 200 amp system.In the US we have at our home 240v. At 200a.
Yes you may be able to draw large currents from your mains but is your ring main rated to handle that current? Probably not and that's probably why it has something like a 30A breaker on it. It prevents fires. Doing it at work makes sense but I'm guess that's 3 phase supply?In the US we have at our home 240v. At 200a.but I'm doing this at work where I have 480v.200a. If need don't think I'll required that though I won't know what my true wattage will be till its built but I can say it's for breaking bonds in the impurities in the water
We don't use a ring main system here in the US. All of our residential systems ar based on three wire, with earth ground, split single phase systems (120 - 0 - 120 with 240 across the two 120 ends) which will allow for drawing a substantial amount of current on a single line if you need to.Yes you may be able to draw large currents from your mains but is your ring main rated to handle that current? Probably not and that's probably why it has something like a 30A breaker on it. It prevents fires.
Ahhh I did not know this thank youWe don't use a ring main system here in the US. All of our residential systems ar based on three wire, with earth ground, split single phase systems (120 - 0 - 120 with 240 across the two 120 ends) which will allow for drawing a substantial amount of current on a single line if you need to.
Around here a standard 200 amp home service would have 4/0 size cable supplying the two 120 VAC sides of the split 240 VAC supply and a 2/0 - 4/0 center for the common/earth ground line as well all designed and rated to handle at least 80% of rated capacity continuous duty.
I haven't read the other posts yet, but general rule is 1,000 microfarads per amp assuming full wave rectification at 60 Hz. So 100,000 microfarads? This doesn't have to be one capacitor. I suspect better calculations can be made.I need help sizing a capacitor for a 1600v. 100 amp full wave bridge rectifier my input will be 120v ac output 120v dc but will vary between 120 to 0 and my amperage will vary between 0 and 100
That's sort of true but mostly for low voltage power supplies where a less than half a volt ripple at 120 Hz accounts for more than 5 - 10% of the working voltage.but general rule is 1,000 microfarads per amp assuming full wave rectification at 60 Hz. So 100,000 microfarads? This doesn't have to be one capacitor. I suspect better calculations can be made.
| D | DC motor controller/power supply | Power Electronics | 17 | |
Alternative power supply | Power Electronics | 1 | |
| D | My Dual Polarity Power Supply | Power Electronics | 37 | |
| S | Green Laser power supply | General Electronics Chat | 23 | |
| J | Power supply with LM317 Advices Needed - Part 2 | Power Electronics | 18 |
