Cant find the power supply connection in bass preamp schematic
Hi guys, recently im looking for a bass preamp schematic and this site Bass Guitar Amp 1 got my interest. But the problem is the power supply connection is not indicated in the schematic, I am confused wich pin in the ic should i put the PS connection, i cannot tell if the project uses dual voltage positive, negative, and ground pwer supply or maybe a common positive, ground power supply? Are all the circuit uses the same power supply? Thank you in advance....
