Power supply and automatic lock
sugandha sharma 1
Joined Apr 24, 2019
11
Hi All
I have designed a circuit but. I have tested 12V to 5V supply, it is working correctly but 12V to 3.3V is not converting and ASM1117 has got burnt. I am not able to identify the issue. Kindly help me in this.
metermannd
Joined Oct 25, 2020
472
Is there any reason why you can't go from 12V to 5V to 3.3V?
The 7805 has to convert a 7V drop (times output current) to heat, but the 3.3V regulator is being asked to convert 8.7V (times output current) to heat.
But if you feed the 3.3V regulator from the 5V rail, then you only need worry about 1.7V (times output current).
sugandha sharma 1
Joined Apr 24, 2019
11
Let me correct this and check.
Sensacell
Joined Jun 19, 2012
3,789
If you cascade the 5V regulator into the 3.3V you still burn the 2 Watts, but at lease it's divided between the two parts.
The next level of efficiency (cool running) is to switch over to a switching regulator. (more expensive, noisy, but greater conversion efficiency)
38,868
You can also add a power resistor in series with the 3.3V regulator input to dissipate some of the heat.
For example a 3W, 27Ω, resistor in series will drop 6.75V and dissipate 1.7W @ 250mA, leaving 0.5W to be dissipated by the regulator, which should keep it at an acceptable temperature.
Note that the resistor will get quite warm.
sugandha sharma 1
Joined Apr 24, 2019
11
I have soldered components for supply only. Issue is there only. No more components I have soldered apart from power supply right now.
sugandha sharma 1
Joined Apr 24, 2019
11
38,868
By that, do you mean there is no output load on the supply?
If so, then you problem is likely a wiring mistake.
Carefully check the wiring against the schematic.
sugandha sharma 1
Joined Apr 24, 2019
11
Problem is solved now. I am converting 5V to 3.3V now.
New problem is I am able to program Atmega328P but not able print the data on serial monitor through FTDI. Same code with FTDI is working on other hardware PCB but not with my PCB.
sugandha sharma 1
Joined Apr 24, 2019
11
