Power dissipation in bridge rectifier
Papabravo
Joined Feb 24, 2006
22,084
Dice is actually the plural of die. It refers to the raw silicon chip without the surrounding package. If I had to guess the bridge might be implemented on one die or two dice.
ian field
Joined Oct 27, 2012
6,536
I would go with a "per die" specification and the rating for 2 die conducting at once - in normal operation; only 2 die should be conducting at once, so there's no reason for all 4 at once.
Papabravo
Joined Feb 24, 2006
22,084
I'm not saying the usage is correct, I'm just commenting on the etymology of the word which was appropriated by the semiconductor industry from an entirely different environment.
wayneh
Joined Sep 9, 2010
18,125
I believe "dice" is a misuse and it should be "dies". Dice is only the plural of die when referring to the game cubes, not when talking about a mechanical mold.
Papabravo
Joined Feb 24, 2006
22,084
It has been a matter of some dispute for nearly 45 years. Can't remember the last time it came up.
johndeaton
Joined Sep 23, 2015
63
Thanks everyone. I'll go with the 250 C/W to be safe (although that really limits the amount of current I can source). Truth be told, this was really the wrong application for that part. Oh well. Learning from mistakes is the best way :)
