Yes an old analog.
I also dug out this ancient RS module, 2 AA cells to 9v. Chip is BP51C.
Only gives 9.09v out with 1.2k load with 48mA input at 2.5v, so 58% efficient. However, I want to power LT1115 so a resistor divider for the virtual earth 0v rail isn't going to work. Hence needing a true + - supply.
I could scope this RS module out and use a capacitor and diodes to provide a negative rail. Possibly.
Only gives 9.09v out with 1.2k load with 48mA input at 2.5v, so 58% efficient. However, I want to power LT1115 so a resistor divider for the virtual earth 0v rail isn't going to work. Hence needing a true + - supply.I could scope this RS module out and use a capacitor and diodes to provide a negative rail. Possibly.
