Excellent information. If I can scrounge up those components I may try your suggestion just to possibly learn something. In the mean time I've gone ahead and ordered another heater element. I am almost sure that is where the problem is. Thanks for the info.Leakage to chassis is normal. If its only a few milliamps, then it is probably safe. Underwriters Laboratories requires 100% leakage testing on most AC operated consumer appliances (maybe all of them), so if your rotisserie has a UL label and the safety was not compromised by your repair you are probably ok.
Edit: (add) A GFIC probably wouldn't hurt; I use them on non-grounded appliances indoors and out.
Using a three wire power plug and connecting the earth wire to the chassis will reduce the chance of shock or annoying tingle when the appliance is touched (I did this with my refrigerator and computer -neither came with a three conductor cord).
You can measure the leakage current from the chassis to earth by running a wire between earth and the chassis and inserting a 1.5k resistor shunted with a .15 uf capacitor, then measuring the AC voltage across the resistor and calculating the current through it.
For safety, in your test, only connect your meter and shunt (R and C) to earth and not to Neutral.
The images above are from the publication at the URL below (Electrical Safety Testing Reference Guide). It contains a good tutorial on the subject.
www.psma.com/ul_files/forums/safety/estguide2.pdf
