PMosfet replace Pjfet
Zeeus
Joined Apr 17, 2019
616
really don't know why can't get this simple task done
Someone kindly assist. Trying to replace the JFET with a MOSFET as title says, to still get oscillation
Thanks
ericgibbs
Joined Jan 29, 2010
21,562
hi Z,
In order to get assistance, you have to tell us what is the problem.
Your asc circuit has disconnected components, also where is the test point for the Output signal.
Post your 'oscillation' images and plots.
E
Zeeus
Joined Apr 17, 2019
616
Thanks E
But i am trying to accomplish same stuff with MOSFET
With no diode (D3) at the output.
Output is output of 2nd op amp
Zeeus
Joined Apr 17, 2019
616
Hmmm..So no depletion PMOS
Thanks..That's what TS needed
Guess there was something to learn in the class he missed on MOSFET
Thanks
dl324
Joined Mar 30, 2015
18,454
Thank you for using something more descriptive than FET. There are many kinds of FETs, but not all FETs are MOSFETs or JFETs; and MOSFETs generally can't be used in place of JFETs. Sloppy descriptions lead to confusion.
A JFET is on with no gate bias and an N channel JFET requires a negative Vgs to turn it off.
A depletion mode N channel MOSFET will also be on with zero gate bias, but you can turn it on harder with a positive Vgs. Enhancement mode are much more common than depletion mode. Sadly, the symbol used for enhancement mode MOSFETs has a dashed line that most of us don't use when we draw schematics by hand:
In my 3 decades of working with memory/microprocessor designs, no one drew (by hand) enhancement mode MOSFETs with a dashed line. Which further adds confusion...
In NMOS only designs, favored back when CMOS was slower, they used a depletion mode device for the load resistor.
