Bingo! It's so simple to put a wrench on a pipe fitting and unscrew/screw it that you could teach an assistant to do it in one day.Plumbing is not the only profession with this sort of tendency. I think that the closer a profession is to being "something that anybody could do," ...
I don't know what forum that guy's been visiting, but every disposal I can think of has been on the right side. My old house, my mother's house, my sister's house, my other sister's house, and on and on. Come to think of it, I don't think I've ever seen one on the left side.A couple of weeks ago I went to the orange hardware store and the resident plumber told me I couldn't put the disposer on the right tub of a dual tub kitchen sink.
It depends on the level of skill vs the level of charge! Someone that cleans my floors has lots of skill too, but if they tried to enforce $150 an hour for floor cleaning by the use of a big nasty union, that attacked people that would clean your floor for less than $150, then they should be "openly put down".... It's a sad day on any forum that claims some technical expertise, when they openly put down other skilled groups.
I hear you, but...It depends on the level of skill vs the level of charge! Someone that cleans my floors has lots of skill too, but if they tried to enforce $150 an hour for floor cleaning by the use of a big nasty union, that attacked people that would clean your floor for less than $150, then they should be "openly put down".
Extortion is charging much more than the true value of something, backed up by force.
I replaced a hot water system and the "plumbing" part consisted of unscrewing two pipe fittings, and adding some teflon tape and screwing them back up. It was NOT a $150/hour value job for your "skilled group" it was the type of simple low-pay job I could teach a 12 yr old to do in 30 minutes.
'Need' = profit, union or none. No doubt a number of unions have been fronts for other activities, but on the same token, unions have been largely responsible for workers rights. I've worked both sides of the fence and don't have a problem with unions.Now if the TV was stupidly simple, and the ONLY thing inside was 2 resistors, then I would have needed *a union* to enforce me still getting $100 for the repair...
| Thread starter | Similar threads | Forum | Replies | Date |
Any Plumbers present? | Off-Topic | 23 | |
| M | Using union in Embedded Project | Programming & Languages | 13 | |
Query for Structure and Union in C Language | Jobs & Career Advising | 14 | |
| M | How union share the same memory | Programming & Languages | 27 | |
Confused on union vs structure | Programming & Languages | 15 |
