pls delete
Thread Starter FranciscoB Joined Feb 8, 2014 138 Feb 10, 2021 #1 pls delete Last edited: Feb 13, 2021
S sghioto Joined Dec 31, 2017 8,634 Feb 11, 2021 #2 I would change the resistor to a 10K otherwise should work OK.
Wolframore Joined Jan 21, 2019 2,619 Feb 11, 2021 #3 The ESP32 has a RTC, research deep sleep, it consumes 10 uA.
S sghioto Joined Dec 31, 2017 8,634 Feb 11, 2021 #4 Its that the same spec for the ESP-32Cam? From what I read the Cam version says 6 ma in deep sleep. Last edited: Feb 12, 2021
Thread Starter FranciscoB Joined Feb 8, 2014 138 Feb 12, 2021 #5 pls delete Last edited: Feb 13, 2021
S sghioto Joined Dec 31, 2017 8,634 Feb 12, 2021 #6 Check the voltage on the gate of the mosfet when the DS3231 is low with the micro connected to the drain.
S sghioto Joined Dec 31, 2017 8,634 Feb 12, 2021 #7 In the last photo I don't see the gate connected to the DS3231. Last edited: Feb 12, 2021
Thread Starter FranciscoB Joined Feb 8, 2014 138 Feb 13, 2021 #9 pls delete Last edited: Feb 13, 2021
Wolframore Joined Jan 21, 2019 2,619 Feb 13, 2021 #10 the INT/SQW output is an alarm/interrupt/aquarewave output, I’m not certain that I can output a steady signal to hold your MOSFET on. DS3231
