PIC32 Ethernet Start Kit - Decoupling Caps
Hurdy
Joined Feb 27, 2006
137
Hi everyone,
Thank you for taking the time out to read this post.
My questions is about the decoupling capacitors between Vdd and various chip pins on the PIC32 Ethernet Starter Kit
I understand that you need decoupling capacitors between Vdd and various pins to help smooth out any noise on the Vdd rail.
I'm trying to create my very first design based on the Ethernet Starter Kit, with a few modifications (it's a good learning curve).
If you look at the PIC32 Ethernet Starter Kit Guide here, and scroll to page 22.
You will notice on the Texas Instruments PHY DP83848C (U8) chip that pin 39 is pulled up to Vdd via a 2.2K resistor.
Should Pin 39 on U8 also have a 0.1uF capacitor tied between it and GND?
Is the rule that any chip pin connected to Vdd, even with a pull up resistors or other components should have a decoupling capacitor?
Many thanks,
Rob
35,159
The purpose of decoupling capacitors is to remove switching noise on the power supply lines. The capacitor is placed between Vcc and GND, or VDD and VSS (ground or DGND) as close as possible to the corresponding pins of each IC. SMD ceramic 0.1μF capacitors are highly recommended.
Pin-39 of U8 DP83848C is a control pin, not a supply pin.
You do not use decoupling capacitors in this case.
There are special cases where filter capacitors are used on signal/control lines, for example, RESET, NRST, MCLR or PFOUT.
When the component manufacturer provides application notes and circuit schematics, follow their recommendations.
Hurdy
Joined Feb 27, 2006
137
Brilliant, thank you both very much.
I just wanted to be sure that the decoupling caps are for Vdd supply rails only (with a few exceptions as you mentioned).
Really appreciate the feedback.
Rob
takao21203
Joined Apr 28, 2012
3,702
When the pins measure a short I dont see a point using capacitors for each one.
However,
1) Be generous with caps for PIC32, two tantalum or 4.7uF etc. suitable ceramic caps
2) AVdd must be connected or the PIC can not even be read out
3) Some applications may require the caps on all pins like instructed in the datasheet
So you need at least 2 capacitors. 100nF is not good enough in my opinion. One across Vcc/Vdd, and the other from the interal regulator to GND.
