PIC18f27k42 EEPROM
Picbuster
Joined Dec 2, 2013
1,062
Format using to read/write to eeprom has changed according to error message and an advice to use MCC.
However MCC is not working on my systems.
char data = EEPROM_read (byte) or char data = __EEPROM_read (byte) does not work anymore.
also not valid for this PIC EEADRH , EEADR , EEDATA , EECON1bits.EEPGD , EECON1bits.CFGS , EECON1bits.WREN
I can not find any information to solve this easy. The only way is to build, from data sheet, my own.
Anybody to give me a hint or a link allowing me to solve this easy?
Thanks in advance.
Picbuster
From MMC for the K42, XC8 4.00 PRO
C:
  MEMORY Generated Driver API Header File
  @Company
    Microchip Technology Inc.
  @File Name
    memory.h
  @Summary
    This is the generated header file for the MEMORY driver using PIC10 / PIC12 / PIC16 / PIC18 MCUs
  @Description
    This header file provides APIs for driver for MEMORY.
    Generation Information :
        Product Revision  :  PIC10 / PIC12 / PIC16 / PIC18 MCUs - 1.81.8
        Device            :  PIC18F57K42
        Driver Version    :  2.1.3
    The generated drivers are tested against the following:
        Compiler          :  XC8 2.36 and above
        MPLAB             :  MPLAB X 6.00
    (c) 2018 Microchip Technology Inc. and its subsidiaries.
    Subject to your compliance with these terms, you may use Microchip software and any
    derivatives exclusively with Microchip products. It is your responsibility to comply with third party
    license terms applicable to your use of third party software (including open source software) that
    may accompany Microchip software.
    THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
    EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY
    IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS
    FOR A PARTICULAR PURPOSE.
    IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
    INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
    WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP
    HAS BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO
    THE FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL
    CLAIMS IN ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT
    OF FEES, IF ANY, THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS
    SOFTWARE.
#ifndef MEMORY_H
#define MEMORY_H
  Section: Included Files
#include <stdbool.h>
#include <stdint.h>
#ifdef __cplusplus  // Provide C++ Compatibility
    extern "C" {
#endif
  Section: Macro Declarations
#define WRITE_FLASH_BLOCKSIZE    128
#define ERASE_FLASH_BLOCKSIZE    128
#define END_FLASH                0x020000
  Section: Flash Module APIs
  @Summary
    Reads a data byte from Flash
  @Description
    This routine reads a data byte from given Flash address
  @Preconditions
    None
  @Param
    flashAddr - Flash program memory location from which data has to be read
  @Returns
    Data byte read from given Flash address
  @Example
    <code>
    uint8_t    readByte;
    uint32_t    flashAddr = 0x7D00;
    readByte = FLASH_ReadByte(flashAddr);
    </code>
uint8_t FLASH_ReadByte(uint32_t flashAddr);
  @Summary
    Reads a data word from Flash
  @Description
    This routine reads a data word from given Flash address
  @Preconditions
    None
  @Param
  @Returns
    Data word read from given Flash address
  @Example
    <code>
    uint16_t    readWord;
    readWord = FLASH_ReadWord(flashAddr);
    </code>
uint16_t FLASH_ReadWord(uint32_t flashAddr);
  @Summary
    Writes a data byte into Flash
  @Description
    This routine writes the given data byte into mentioned Flash address.
    This routine intially reads block of data (from Flash) into RAM, updates
    data values in RAM, and writes back updated values to Flash.
  @Preconditions
    None
  @Param
    flashAddr      - Flash program memory location to which data has to be written
    *flashRdBufPtr - Pointer to RAM buffer of size 'ERASE_FLASH_BLOCKSIZE' at least
    byte           - Data byte to be written in Flash
  @Returns
    None
  @Example
    <code>
    uint8_t    writeData = 0xAA;
    uint8_t    Buf[ERASE_FLASH_BLOCKSIZE];
    FLASH_WriteWord(flashAddr, Buf, writeData);
    </code>
void FLASH_WriteByte(uint32_t flashAddr, uint8_t *flashRdBufPtr, uint8_t byte);
  @Summary
    Writes data to complete block of Flash
  @Description
    This routine writes data bytes to complete block in Flash program memory
  @Preconditions
    None
  @Param
    writeAddr      - A valid block starting address in Flash
    *flashWrBufPtr - Pointer to an array of size 'WRITE_FLASH_BLOCKSIZE' at least
  @Returns
    -1, if the given address is not a valid block starting address of Flash
    0, in case of valid block starting address
  @Example
    <code>
    #define FLASH_ROW_ADDRESS     0x7D00
    uint8_t wrBlockData[] =
        0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F,
        0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1E, 0x1F,
        0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2A, 0x2B, 0x2C, 0x2D, 0x2E, 0x2F,
        0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39, 0x3A, 0x3B, 0x3C, 0x3D, 0x3E, 0x3F
    // write to Flash memory block
    FLASH_WriteBlock((uint32_t)FLASH_ROW_ADDRESS, (uint8_t *)wrBlockData);
    </code>
int8_t FLASH_WriteBlock(uint32_t writeAddr, uint8_t *flashWrBufPtr);
  @Summary
    Erases complete Flash program memory block
  @Description
    This routine erases complete Flash program memory block
  @Preconditions
    None
  @Param
    baseAddr - A valid block starting address in Flash program memory
  @Returns
    None
  @Example
    <code>
    uint32_t    flashBlockStartAddr = 0x7D00;
    FLASH_EraseBlock(flashBlockStartAddr);
    </code>
void FLASH_EraseBlock(uint32_t baseAddr);
  Section: Data EEPROM Module APIs
  @Summary
    Writes a data byte to Data EEPROM
  @Description
    This routine writes a data byte to given Data EEPROM location
  @Preconditions
    None
  @Param
    bAdd  - Data EEPROM location to which data to be written
    bData - Data to be written to Data EEPROM location
  @Returns
    None
  @Example
    <code>
    uint16_t dataeeAddr = 0x10;
    uint8_t dataeeData = 0x55;
    DATAEE_WriteByte(dataeeAddr, dataeeData);
    </code>
void DATAEE_WriteByte(uint16_t bAdd, uint8_t bData);
  @Summary
    Reads a data byte from Data EEPROM
  @Description
    This routine reads a data byte from given Data EEPROM location
  @Preconditions
    None
  @Param
    bAdd  - Data EEPROM location from which data has to be read
  @Returns
    Data byte read from given Data EEPROM location
  @Example
    <code>
    uint8_t readData;
    readData = DATAEE_ReadByte(dataeeAddr);
    </code>
uint8_t DATAEE_ReadByte(uint16_t bAdd);
void MEMORY_Tasks(void);
#endif
#endif // MEMORY_H
End of File
C:
  MEMORY Generated Driver File
  @Company
  @File Name
    memory.c
  @Summary
    This is the generated driver implementation file for the MEMORY driver using PIC10 / PIC12 / PIC16 / PIC18 MCUs
  @Description
    This file provides implementations of driver APIs for MEMORY.
    SOFTWARE.
#include <xc.h>
#include "memory.h"
    NVMCON1bits.NVMREG = 2;
    TBLPTRU = (uint8_t)((flashAddr & 0x00FF0000) >> 16);
    TBLPTRH = (uint8_t)((flashAddr & 0x0000FF00)>> 8);
    TBLPTRL = (uint8_t)(flashAddr & 0x000000FF);
    asm("TBLRD");
    return (TABLAT);
    return ((((uint16_t)FLASH_ReadByte(flashAddr+1))<<8)|(FLASH_ReadByte(flashAddr)));
    uint32_t blockStartAddr = (uint32_t)(flashAddr & ((END_FLASH-1) ^ (ERASE_FLASH_BLOCKSIZE-1)));
    uint8_t offset = (uint8_t)(flashAddr & (ERASE_FLASH_BLOCKSIZE-1));
    uint8_t i;
    // Entire row will be erased, read and save the existing data
    for (i=0; i<ERASE_FLASH_BLOCKSIZE; i++)
        flashRdBufPtr[i] = FLASH_ReadByte((blockStartAddr+i));
    // Load byte at offset
    flashRdBufPtr[offset] = byte;
    // Writes buffer contents to current block
    FLASH_WriteBlock(blockStartAddr, flashRdBufPtr);
    uint32_t blockStartAddr  = (uint32_t )(writeAddr & ((END_FLASH-1) ^ (ERASE_FLASH_BLOCKSIZE-1)));
    uint8_t GIEBitValue = INTCON0bits.GIE;     // Save interrupt enable
    uint8_t i;
    // Flash write must start at the beginning of a row
    if( writeAddr != blockStartAddr )
        return -1;
    // Block erase sequence
    FLASH_EraseBlock(writeAddr);
    // Block write sequence
    TBLPTRU = (uint8_t)((writeAddr & 0x00FF0000) >> 16);    // Load Table point register
    TBLPTRH = (uint8_t)((writeAddr & 0x0000FF00)>> 8);
    TBLPTRL = (uint8_t)(writeAddr & 0x000000FF);
    // Write block of data
    for (i=0; i<WRITE_FLASH_BLOCKSIZE; i++)
        TABLAT = flashWrBufPtr[i];  // Load data byte
        if (i == (WRITE_FLASH_BLOCKSIZE-1))
            asm("TBLWT");
        else
            asm("TBLWTPOSTINC");
    NVMCON1bits.WREN = 1;
    INTCON0bits.GIE = 0; // Disable interrupts
    NVMCON2 = 0x55;
    NVMCON2 = 0xAA;
    NVMCON1bits.WR = 1; // Start program
    INTCON0bits.GIE = GIEBitValue; // Restore interrupt enable
    NVMCON1bits.WREN = 0; // Disable writes to memory
    return 0;
    TBLPTRU = (uint8_t)((baseAddr & 0x00FF0000) >> 16);
    TBLPTRH = (uint8_t)((baseAddr & 0x0000FF00)>> 8);
    TBLPTRL = (uint8_t)(baseAddr & 0x000000FF);
    NVMCON1bits.FREE = 1;
    NVMCON2 = 0x55;
    NVMCON2 = 0xAA;
    NVMADRH = (uint8_t)((bAdd >> 8) & 0x03);
    NVMADRL = (uint8_t)(bAdd & 0xFF);
    NVMDAT = bData;
    NVMCON1bits.NVMREG = 0;
    NVMCON2 = 0x55;
    NVMCON2 = 0xAA;
    NVMCON1bits.WR = 1;
    // Wait for write to complete
    while (NVMCON1bits.WR)
    INTCON0bits.GIE = GIEBitValue;   // restore interrupt enable
    NVMCON1bits.RD = 1;
    NOP();  // NOPs may be required for latency at high frequencies
    NOP();
    return (NVMDAT);
void MEMORY_Tasks( void )
    /* TODO : Add interrupt handling code */
    PIR0bits.NVMIF = 0;
End of File
Code example using EEPROM and CRC
C:
* read eeprom into temp program variable buffer
bool read_cal_data(void)
    uint16_t x = 0, y;
    uint8_t *r_cal_ptr, crcVal_save;
    y = sizeof(r_cal);
    r_cal_ptr = (uint8_t*) & r_cal;
    // Initialize the CRC module
    CRC_Initialize();
    // Start CRC
    CRC_Start();
    do {
        r_cal_ptr[x] = DATAEE_ReadByte(x);
    } while (++x < y);
    crcVal_save = r_cal.crc;
    if (r_cal.checkmark == EE_CHECKMARK) {
        r_cal.crc = TATE; // standard CRC filler code
        x = 0;
        do {
            CRC_8BitDataWrite(r_cal_ptr[x]);
            while (CRC_IsBusy());
        } while (++x < y);
        if (CRC_CalculatedResultGet(NORMAL, 0x00) != crcVal_save)
            return false;
    } else {
        return false;
    r_cal.crc = crcVal_save; // reload actual eeprom CRC
    return true;
* write program variables to eeprom
void write_cal_data(void)
    uint16_t x = 0, y;
    uint8_t *r_cal_ptr, crcVal;
    y = sizeof(R);
    R.crc = TATE;
    r_cal_ptr = (uint8_t*) & R;
    R.checkmark = EE_CHECKMARK;
    CRC_Initialize();
    // Start CRC
    CRC_Start();
    do {
        DATAEE_WriteByte(x, r_cal_ptr[x]);
    } while (++x < y);
    // Read CRC check value
    crcVal = (uint8_t) CRC_CalculatedResultGet(NORMAL, 0x00);
    // store crc in EEPROM
    DATAEE_WriteByte(sizeof(R) - 1, crcVal);
Picbuster
Joined Dec 2, 2013
1,062
C:
@Company
@File Name
memory.c
@Summary
@Description
SOFTWARE.
#include <xc.h>
#include "memory.h"
asm("TBLRD");
return (TABLAT);
uint8_t i;
uint8_t i;
return -1;
asm("TBLWT");
else
NVMCON2 = 0x55;
NVMCON2 = 0xAA;
return 0;
NVMCON2 = 0x55;
NVMCON2 = 0xAA;
NVMDAT = bData;
NVMCON2 = 0x55;
NVMCON2 = 0xAA;
NVMCON1bits.WR = 1;
NVMCON1bits.RD = 1;
NOP();
return (NVMDAT);
PIR0bits.NVMIF = 0;
End of File
ThankYou !!
good information
Picbuster
