Hello.
Enclosed code is one simple example from Bate's book "Interfacing Pic microcontroller".
The codes run properly in Proteus VMS, but not on EasyPic V7 board (to start and stop blinking I use RB1 and 2 buttons in pull up setting). Only RD6 and RD3 are lighted up constantly, but no light sequence like in the simulation.
I had same problems (not running on easypicv7) for other codes with this 16F877A.
I don't know if it is a problem of configuration or so (I remember in the past that to make 16F628A I had to pull down RB4, for instance...).
I don't know if something similar is needed here...
Thank you for any kind suggestion/advise.
Bye
Mod edit: posted code and schematic from .zip
Bye
Code:
; Source File: LED2.ASM
; Author: MPB
; Date: 2-1-13
; Slow output binary count is stopped, started
; and reset with push buttons.
; Processor: PIC 16F877A
; Hardware: Prototype
; Clock: RC = 40kHz
; Inputs: Port B: Push Buttons
; RB1, RB2 (active low)
; Outputs: Port D: LEDs (active high)
; WDTimer: Disabled
; PUTimer: Enabled
; Interrupts: Disabled
; Code Protect: Disabled
PROCESSOR 16F877 ; Define MCU type
__CONFIG 0x3733 ; Set config fuses
; Register Label Equates....................................
PORTB EQU 06 ; Port B Data Register
PORTD EQU 08 ; Port D Data Register
TRISD EQU 88 ; Port B Direction Register
Timer EQU 20 ; GPR used as delay counter
; Input Bit Label Equates ..................................
Inres EQU 1 ; 'Reset' input button = RD0
Inrun EQU 2 ; 'Run' input button = RD1
CODE 0 ; Program code start address
; Initialise Port B (Port A defaults to inputs).............
BANKSEL TRISD ; Select bank 1
MOVLW b'00000000' ; Port B Direction Code
MOVWF TRISD ; Load the DDR code into F86
BANKSEL PORTD ; Select bank 0
GOTO reset ; Jump to main loop
; 'delay' subroutine ........................................
delay:
MOVWF Timer ; Copy W to timer register
down:
DECFSZ Timer ; Decrement timer register
GOTO down ; and repeat until zero
RETURN ; Jump back to main program
; Start main loop ...........................................
reset:
CLRF PORTD ; Clear Port B Data
start:
BTFSS PORTB,Inres ; Test reset button
GOTO reset ; and reset Port B if pressed
BTFSC PORTB,Inrun ; Test run button
GOTO start ; and repeat if n pressed
INCF PORTD ; Increment output at Port B
MOVLW 0FF ; Delay count literal
CALL delay ; Jump to subroutine 'delay'
GOTO start ; Repeat main loop always
END ; Terminate source code
