Hi, sorry, my English is not good, I'm using the Google translator. I have a problem in the flow of the program in assembly about PIC16F18875, when BTFSC gets 1 then it calls the instruction, CALL subroutine. In the subroutine the bank "banksel porta" is selected and then channel 5 PORTA, 5 is written. But it seems that he does not execute "BANKSEL PORTA" and therefore he does not write ON on PORTA, 5. But if I call BANKSEL before executing CALL subroutine it works fine.
The code, ISR, calls a counter CALL TIMER0_COUNTER. This counter writes data in memory: TIMER01 After, BTFSC TIMER01,4 And if it's 1, CALL SUBRUTINE BLINK_PORTA5 BANKSEL PORTA BSF PORTA, 5 RETURN But BANKSEL PORTA seems not to be executed
ISR CODE 0x0004
;Drive interrupt Timer0
BANKSEL PIR0
BTFSC PIR0,TMR0IF
CALL TIMER0_COUNTER
BTFSC TIMER01,4
CALL BLINK_PORTA5
BANKSEL PIR0
BCF PIR0,TMR0IF
RETFIE
;;;;;SUBRUTINE BLINK PORTA5
BLINK_PORTA5
BANKSEL PORTA *********************** IT IS NOT EXECUTED
BSF PORTA,5
RETURN
TIMER0_COUNTER
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;,,, BANKSEL PORTA ;;;;;;;;;;;;;;;;;;;;;;; HERE IT WORKS!!! WHY!?!?!?!
MOVLW 0x01
ADDWF TIMER00,1
BTFSS STATUS,C
RETURN
MOVLW TIMER00_OVERFLOW
MOVWF TIMER_OVERFLOW
MOVLW 0x01
ADDWF TIMER01,1
BTFSS STATUS,C
RETURN
MOVLW TIMER01_OVERFLOW
MOVLW 0X01
ADDWF TIMER02,1
BTFSS STATUS,C
RETURN
MOVLW TIMER02_OVERFLOW
MOVLW 0X01
ADDWF TIMER03,1
BTFSS STATUS,C
RETURN
MOVLW TIMER03_OVERFLOW
MOVLW 0X01
ADDWF TIMER04,1
BTFSS STATUS,C
RETURN
MOVLW TIMER04_OVERFLOW
MOVLW 0X01
ADDWF TIMER05,1
BTFSS STATUS,C
RETURN
MOVLW TIMER05_OVERFLOW
MOVLW 0X01
ADDWF TIMER06,1
BTFSS STATUS,C
RETURN
MOVLW TIMER06_OVERFLOW
MOVLW 0X01
ADDWF TIMER07,1
BTFSS STATUS,C
RETURN
MOVLW TIMER07_OVERFLOW
RETURN
ISR CODE 0x0004
BANKSEL PIR0
BTFSC PIR0,TMR0IF
CALL TIMER0_COUNTER
BTFSC TIMER01,4
CALL BLINK_PORTA5
BANKSEL PIR0
BCF PIR0,TMR0IF
RETFIE
BLINK_PORTA5
BSF PORTA,5
RETURN
TIMER0_COUNTER
MOVLW 0x01
ADDWF TIMER00,1
BTFSS STATUS,C
RETURN
MOVLW 0x01
ADDWF TIMER01,1
BTFSS STATUS,C
RETURN
MOVLW 0X01
ADDWF TIMER02,1
BTFSS STATUS,C
RETURN
MOVLW 0X01
ADDWF TIMER03,1
BTFSS STATUS,C
RETURN
MOVLW 0X01
ADDWF TIMER04,1
BTFSS STATUS,C
RETURN
MOVLW 0X01
ADDWF TIMER05,1
BTFSS STATUS,C
RETURN
MOVLW 0X01
ADDWF TIMER06,1
BTFSS STATUS,C
RETURN
MOVLW 0X01
ADDWF TIMER07,1
BTFSS STATUS,C
RETURN
RETURN
