hi everyone!i believe i am at the right place...
i bought an immobilizer system to convert it to a keyless entry on a custom motorcycle that i am making,problem is that the seller didnt mention the time delay it has on it.
it works with rfid,when it has 12v on it and the transmitter is out of velosity it turn off after 3 minutes.after some tests i found that if you take off the power supply and reinstall it (like reset) with transmitter out of velosity it still supply power but with less delay (20 seconds).
i unscrew the host module and found that it has a pic12f629 that i believe is the programming chip, would it be easy enough for a newbie to change it so it has no delay(best would be on the reset action where i turn off the motorcycle and and leave then someone can go, turn the switch to "on" and start the engine for 20 seconds)?i've only mess with blown capacitors and resistors on circuits...thats my experiance
