PIC with 16MHz crystal or X4 PLL and 4MHz crystal
AlbertHall
Joined Jun 4, 2014
12,660
I need a stable 16MHz clock for a PIC - constant frequency more important than accurate frequency.
I have the choice of using a 16MHz crystal or a 4MHz crystal with the X4 PLL in the chip.
Which should I choose? Does it make any difference?
hexreader
Joined Apr 16, 2011
619
Much easier to make 4MHz crystal work reliably than 16MHz. Trace lengths and board layout are less critical.
Curious as to exactly which PIC and why you want 16MHz, rather than maximum for (unknown) PIC
JohnInTX
Joined Jun 26, 2012
4,787
I would consider using an external oscillator in a can. You can easily get a couple of orders better accuracy and stability than with the uC's oscillator (without tuning).
