PIC to PIC 2C.
R!f@@
Joined Apr 2, 2009
10,004
I read I2C is not good for off board communication.
I dunno how long distance is.
But I do see equipments like consumer products using SDA and SCL connected thru ribbons.
My question is, say for like 5 inches apart, is off board I2C communication a problem...I do not need high speed.
OBW0549
Joined Mar 2, 2015
3,566
I'm no expert on I2C, but I can't see 5 inches being a big problem, provided the EMC environment isn't too bad and provided also you've got good grounding between the two boards. If I were doing it I'd probably do it with a 6-conductor ribbon configured GND-SDA-GND-GND-SCL-GND. Or maybe with a few extra grounds for good measure...
shteii01
Joined Feb 19, 2010
4,644
I had lcd display that was a couple of feet away from arduino board that we sent data to display using a couple of wires, not even a ribbon, and it worked fine. 5" should be fine.
R!f@@
Joined Apr 2, 2009
10,004
Yaa. All are saying be good to ground..be good to ground.!! :rolleyes:
I do not see why "GND-SDA-GND-GND-SCL-GND." won't be good to ground. :p
Plus The PSU wire will be running separate and two boards will have a ground plane.
ErnieM
Joined Apr 24, 2011
8,415
I made a fixture composed of 1 master and 10 slaves in a 12 x 18 box. The master controlled and powered the slaves over a 4 conductor ribbon cable.
Everything worked just fine, though I did allow for bad data I would require, and the I2C was run a bit slow (100 k perhaps?).
