pic mikroc heart rate monitor question
Hassan Abu al rub
Joined Feb 10, 2019
12
if (TMR1IF_bit){
TMR1IF_bit = 0;
counter++;
if(counter==4){heartplus*60;counter=0; heartplus=0;}
TMR1H = 0x0B; //every 250 ms
TMR1L = 0xDC;
if (TMR0IF_bit){
TMR0IF_BIT=0;
TMR0L=255;
heartplus++;
_____________________________________________________________________
i have heart rate module output is plus 5 volt when i hold sensor with two hand give puls
i need to do some calculation to make simple project
by timer one i do 250 ms and some delay if(counter==4) to give me one second
also time 0 set as counter to count plus
the number i get BPS * 60 to give BPM
but calculation and some thing need to add to my simple code
can any one advice
upand_at_them
Joined May 15, 2010
939
For one thing, when counter == 4 you are doing this: "heartplus*60", which means nothing since it isn't assigned to a variable. And in the same block of code you are setting heartplus = 0...Is that what you intended to do?
