Here is my attempt at simple...Can you make it simple. just make code for ds1307 only.
Code:
#define _XTAL_FREQ 20000000 // crystal 20MHz
// PIC18F45K80 Configuration Bit Settings
// CONFIG1L
#pragma config RETEN = ON // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2 // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON // Power Up Timer (Enabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0 // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1 // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5 // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON // Code Protect Boot (Enabled)
#pragma config CPD = ON // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON // Config. Write Protect (Enabled)
#pragma config WRTB = ON // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#pragma warning disable 520
#include <xc.h>
unsigned char Result1;
unsigned char Result2;
unsigned char Result3;
unsigned char Result4;
// The code should set the R/W bit according to its function
#define DS1307_ADDRESS 0xD0 //I2C slave address of DS1307 (8 bit format)
#define Word_Address 0x00
#define LCD_RS LATBbits.LATB4
#define LCD_TRIS_RS TRISBbits.TRISB4
#define LCD_RW LATBbits.LATB5
#define LCD_TRIS_RW TRISBbits.TRISB5
#define LCD_E LATBbits.LATB6
#define LCD_TRIS_E TRISBbits.TRISB6
#define LCDPORT LATD
#define LCDTRISD LATD
//Prototype function
void Port_Initialized (void);
void WriteNibble(unsigned char command);
void WaitLCDBusy(void);
void WriteCommand(unsigned char command);
// LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
LATD = 0x00;
LATE = 0x00;
// TRISx registers
TRISA = 0x00; // All are output, Unused
TRISB = 0x00; // all are output, Unused
TRISC = 0x18; //
TRISD = 0x00; // all are output, Unused
TRISE = 0x00; // All are output, Unused
ANCON0 = 0x00; // digital port
ANCON1 = 0x00; // Set to digital port
CM1CON = 0x00; // Comparator off
CM2CON = 0x00; // Comparator off
ADCON0 = 0x00; // A/D conversion Disabled
ADCON1 = 0x00; // A/D conversion Disabled
ADCON2 = 0x00; // A/D conversion Disabled
__delay_ms(5);
//Send a command to the LCD
WaitLCDBusy(); //wait until not busy
LCD_RS = 0; //setup to send command
WriteNibble(command); //write the high nibble
WriteNibble( (unsigned char)(command<<4) ); //then the low nibble
//Initialized LCD
void LCD_Initialized()
LCDTRISD &=0x0f; //ensure data bits are output
LCD_E=0; //clear enable
LCD_RS = 0; //going to write command
LCD_TRIS_E=0; //Set enable to output
LCD_TRIS_RS=0; //set RS to output
LCD_TRIS_RW=0;
LCD_RW=0;
__delay_ms(30); //delay for LCD to initialise.
WriteNibble(0x30); //Required for initialisation
__delay_ms(5); //required delay
__delay_ms(1); //required delay
WriteCommand(0x20); //set to 4 bit interface
WriteCommand(0x2c); //set to 4 bit interface, 2 line and 5*10 font
WriteCommand(0x01); //clear display
WriteCommand(0x06); //move cursor right after write
WriteCommand(0x0C); //turn on display
//Send a character to the LCD
void WriteChar(unsigned char chr)
LCD_RS=1; //Setup to send character
WriteNibble(chr); //write the high nibble
WriteNibble( (unsigned char)(chr<<4)); //then the low nibble
//Send any 4 bits to the LCD
LCDPORT &= 0x0f; //clear the data bits
LCDPORT|=((command & 0xf0)); //or in the new data
LCD_E = 1; //enable the LCD interface
NOP(); //change to delay of 1uS
NOP();
NOP();
LCD_E = 0; //disable it
void LCD_Data( unsigned char *string)
while (*string != '\0')
WriteChar(*string);
string++;
//Initialize I2C in master mode
void I2C_Initialized(void)
SSPSTAT=0x80; //Slew rate control is disabled for Standard Speed mode (100 kHz and 1 MHz)
SSPCON1=0x28; // I2C Master mode, clock = FOSC/(4 * (SSPADD + 1))
SSPCON2=0x00;
SSPADD = 49; //100kHz clock @ 20MHz Fosc SSPADD = ( (Fosc/4) / BiteRate )-1
// SSPADD = ( 20MHz / 100KHz ) - 1 = 49 //
// Send an I2C START
// Return 0 if all ok, 1 if bus collision
__bit I2C_Start(void)
BCLIF = 0; //Clear 'Bus collision" flag
SEN = 1; //initiate a START cycle
while (SEN); //wait until it has been sent
return BCLIF; //return value of BCLIF flag
// Send an I2C STOP
void I2C_Stop(void)
PEN = 1; //initiate a STOP cycle
while (PEN); //wait until it has been sent
// Send an I2C REPEATED START
void I2C_Restart(void)
RSEN = 1; //initiate a REPEATED START cycle
while (RSEN); //wait until it has been sent
//Receive one byte. ackflag=0 to send ACK, or 1 to send NAK in reply
//Send one byte. Return 0 if ACK received, or 1 if NAK received
__bit I2C_Sendbyte(unsigned char dat)
SSPBUF = dat;
asm("nop"); // <<<--- wait a little for R_W to be set
while (R_W); //wait until byte sent and ACK/NAK received
return ACKSTAT;
unsigned char I2C_Recvbyte(unsigned char ackflag)
RCEN = 1; // initiate a RECEIVE cycle
ACKDT =(__bit)ackflag; //specify if we should send ACK or NAK after receiving
while (RCEN); //wait until RECEIVE has completed
ACKEN = 1; //initiate an ACK cycle
while (ACKEN); //wait until it has completed
return SSPBUF;
//Send an array of data to an I2C device.
//Return 0 if all OK, 1 if bus error, 2 if slave address NAK, 3 if slave register NAK, 4 if slave data NAK
unsigned char DS1307_Write(unsigned char slave_address, unsigned char start_reg, unsigned char buflen, const unsigned char * bufptr)
if (I2C_Start() ) //send a start, and check if it succeeded
return 1; //abort if bus collision
//send the I2C slave address (force R/W bit low)
if (I2C_Sendbyte(slave_address & 0xfe)) // <<---- Added AND to force R/W- low. Comment said it but code didn't do it
I2C_Stop(); //if address was NAKed, terminate the cycle
return 2; //and return error code
//send the device register index
if (I2C_Sendbyte(start_reg))
I2C_Stop(); //if register was NAKed, terminate the cycle
return 3; //and return error code
//send the data. buflen might be zero!
for (; buflen>0; --buflen)
if (I2C_Sendbyte(*bufptr++))
return 4; //and return error code
I2C_Stop();
return 0; //no error
//Receive an array of data from an I2C device.
unsigned char DS1307_Read(unsigned char slave_address, unsigned char start_reg, unsigned char buflen, unsigned char * bufptr)
//do a dummy zero length write cycle to set the register address
unsigned char retval = DS1307_Write(slave_address, start_reg, 0, 0);
if (retval)
return retval; //abort if there was an error
//now start the READ cycle
//send the I2C slave address (force the R/W bit high)
if (I2C_Sendbyte(slave_address | 0x01))
//receive the data.
unsigned char ackflag = (buflen == 1); //1 if this is the last byte to receive => send NAK
*bufptr++ = I2C_Recvbyte(ackflag);
I2C_Stop();
const unsigned char DS1307_data[] =
0x00, // seconds
0x00, // minutes
0x12, // hours
0x07, // day
0x23, // date
0x05, // month
0x01, // year
unsigned char rd_buf[7];
// Test variable for one byte transfer
const unsigned char testchar = 'A';
unsigned char testchar_readback[17]; // init to this to see difference after read
void main(void)
unsigned char i = 0;
unsigned char Data2 [17] = "tst ";
unsigned char old_second = 99;
Port_Initialized ();
LCD_Initialized();
I2C_Initialized();
LCD_Data(Data2);
// Write test buffer
Result1 = DS1307_Write(DS1307_ADDRESS , Word_Address , sizeof(DS1307_data), DS1307_data);
__delay_ms(10);
// Read test buffer back
Result2 = DS1307_Read(DS1307_ADDRESS, Word_Address , sizeof(rd_buf), rd_buf) ;
__delay_ms(10);
// Write Minutes 1 minute to location 0x1, size 1
//Result3 = DS1307_Write(DS1307_ADDRESS, 0x01 , 1, 31);
__delay_ms(10);
while(1){
__delay_ms(100); // limit read rate of RTC
Result4 = DS1307_Read(DS1307_ADDRESS, 0 , 7, testchar_readback); // read RTC registers
if(old_second != (testchar_readback[0] & 0x0f)){ // only allow LCD update if seconds units have changed
LCD_Initialized();
Data2[0] = ((testchar_readback[4] >> 4) & 0x0f) + '0';
Data2[1] = (testchar_readback[4] & 0x0f) + '0';
Data2[2] = ((testchar_readback[5] >> 4) & 0x0f) + '0';
Data2[3] = (testchar_readback[5] & 0x0f) + '0';
Data2[4] = '2';
Data2[5] = (testchar_readback[6] & 0x0f) + '0';
Data2[6] = ' ';
Data2[7] = ((testchar_readback[2] >> 4) & 0x0f) + '0';
Data2[8] = (testchar_readback[2] & 0x0f) + '0';
Data2[9] = ':';
Data2[10] = ((testchar_readback[1] >> 4) & 0x0f) + '0';
Data2[11] = (testchar_readback[1] & 0x0f) + '0';
Data2[12] = ':';
Data2[13] = ((testchar_readback[0] >> 4) & 0x0f) + '0';
Data2[14] = (testchar_readback[0] & 0x0f) + '0';
Data2[15] = ' ';
Data2[16] = 0;
LCD_Data(Data2);
old_second = testchar_readback[0] & 0x0f; // prevent next LCD update until seconds have chanaged
