Hi all,
I'm using a PIC18F4520 to control 2 transistors. I've setup 2 channel PWM and it is working fine, but when I go to setup the delay between the two channels nothing happens.
Information on setup:
osc is 12Mhz
freq of pwm about 43khz
duty cycle is about 40% per channel.
Any help would be great, Thanks
Code:
;Start of main program
Main:
banksel TRISC
movlw b'00000010'
movwf TRISC
movlw b'00010000'
movwf TRISD
banksel PR2
movlw b'01000000'
movwf PR2
banksel CCPR1L
movlw b'00011010'
movwf CCPR1L
movlw b'10001100'
movwf CCP1CON
banksel PWM1CON
movlw b'00001000' ;Bit 7 sets auto reset
movwf PWM1CON ;Bits 6:0 Dead Band Delay
banksel PIR1
bcf PIR1,TMR2IF
banksel T2CON
movlw b'00000100' ; Sets up the timer w/ a 1/16 scaler
movwf T2CON ; Timer2 Register
banksel TRISC
clrf TRISC
clrf TRISD
banksel ECCP1AS
bcf ECCP1AS,ECCPASE
osc is 12Mhz
Code:
Main:
banksel TRISC
movlw b'00000010'
movwf TRISC
movlw b'00010000'
movwf TRISD
banksel PR2
movlw b'01000000'
movwf PR2
banksel CCPR1L
movlw b'00011010'
movwf CCPR1L
movlw b'10001100'
movwf CCP1CON
banksel PWM1CON
banksel PIR1
bcf PIR1,TMR2IF
banksel T2CON
banksel TRISC
clrf TRISC
clrf TRISD
banksel ECCP1AS
bcf ECCP1AS,ECCPASE
