PIC Assembler Observation
be80be
Joined Jul 5, 2008
2,395
You have lost your mind just kidding but you don't have to use 0x10 you could just use
b'00001010' or put radx dec and just use a 10
Keep away from using hex you'll be lost more then you are now.
Use bin 10101010 or dec 0 to 255
I stay with just bin cause you can see the bit's
PICNewbee
Joined Mar 31, 2017
355
Burt
'Keep away from using hex'
Just to keep it simple.
I used hex because in datasheet register addresses are in hex.
'I stay with just bin'
Yes. I loaded register with a binary value.
Seems like everything is in order.
Program
MOVLW b'11111111'
MOVWF 0x10
PICNewbee
Joined Mar 31, 2017
355
Max
Label?
My next step was to create a variable and see where it ends up with IPE.
That's my 'Mickey Mouse Club' debugger for the moment.
Label? I get that bad feeling it might be different than a variable.
Will look at datasheet and tutorial to gleen some info from them.
PICNewbee
Joined Mar 31, 2017
355
I will just throw this question in here instead of starting a new post.
Will the calibration data initialization code in the Microchip be stable?
Just being cautious.
Gooligum does it a little different. Will compare them later.
PICNewbee
Joined Mar 31, 2017
355
Here's Gooligum 10F200 program with internal oscillator inititialization code.
;***** RC CALIBRATION
RCCAL CODE 0x0FF ; processor reset vector
res 1 ; holds internal RC cal value, as a movlw k
;***** RESET VECTOR *****************************************************
RESET CODE 0x000 ; effective reset vector
movwf OSCCAL ; apply internal RC factory calibration
I guess I can fine tune it later.
Microchip template should work okay..
PICNewbee
Joined Mar 31, 2017
355
Here's template again.
RESET_VECTOR CODE 0xFF ; processor reset vector
; Internal RC calibration value is placed at location 0xFF by Microchip
; as a movlw k, where the k is a literal value.
MAIN CODE 0x000
movwf OSCCAL ; update register with factory cal value
start
nop ; example code
movlw 0xFF ; example code
movwf temp ; example code
I am a little suspicious of 0xFF showing up twice there.
I think Microchip might be trying to say something that can be trouble later.
PICNewbee
Joined Mar 31, 2017
355
Max
You say 12Fxxx include file.
I am working with 10F200.
Look at 12Fxxx anyway?
Where are the include files? How do I open them?
PICNewbee
Joined Mar 31, 2017
355
Okay.
10F200 Include file is on the root in MPASM suite. Opened it with Notepad.
Saw a lot of EQU's but no T1CON.
MaxHeadRoom
Joined Jul 18, 2013
30,813
If you have MPLAB, go to directory, Program files/ Microchip/MASM suite and you will find all the *.inc files there, I think the very first is the 10f200!
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,813
Okay.
Because the 10f does not have one, I was mistaken, I thought you were using 12f.
It is still easier when you designate a memory location by label.
Max.
PICNewbee
Joined Mar 31, 2017
355
Max
'It is still easier when you designate a memory location by label.'
Sure.That first program just gets it done.
Not an example of 'Good Coding Practices' at all.
be80be
Joined Jul 5, 2008
2,395
This is what your using
Code:
    list        p=10F200
    #include    <p10F200.inc>
;***** CONFIGURATION
                ; ext reset, no code protect, no watchdog
    __CONFIG    _MCLRE_ON & _CP_OFF & _WDT_OFF
;***** MAIN PROGRAM *****************************************************
;***** Initialisation
start
        movlw   b'1101'         ; configure GP1 (only) as an output
        tris    GPIO
        movlw   b'0010'         ; set GP1 high
        movwf   GPIO
;***** Main loop
        goto    $               ; loop forever
        END
This is mplab
Code:
    list      p=10F200            ; list directive to define processor
    #include <p10F200.inc>        ; processor specific variable definitions
; '__CONFIG' directive is used to embed configuration word within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
;***** VARIABLE DEFINITIONS
TEMP_VAR    UDATA
temp        RES     1             ;example variable definition
MAIN    CODE    0x000
start
    nop                       ; example code
; remaining code goes here
    END                       ; directive 'end of program'
Do you not see "example code in this " mean it's just there to show you how.
Code:
start
    nop                       ; example code
be80be
Joined Jul 5, 2008
2,395
If you wrote some code using the template it would look like this
Code:
;   This file is a basic code template for object module code         *
;   generation on the PIC10F200. This file contains the               *
;   basic code building blocks to build upon.                         *
;   Refer to the MPASM User's Guide for additional information on     *
;   features of the assembler and linker.                             *
;   Refer to the respective PIC data sheet for additional             *
;   information on the instruction set.                               *
;    Filename:        xxx.asm                                           *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:                                                          *
;    Company:                                                         *
;    Files required: P10F200.INC                                      *
;    Notes:                                                           *
TEMP_VAR    UDATA
MAIN    CODE    0x000
start
        tris    GPIO
        movwf   GPIO
;***** Main loop
        END
Please look at all 3 code post
be80be
Joined Jul 5, 2008
2,395
See this
Code:
movwf   temp
And this
Code:
[LIST=1]
[*];***** VARIABLE DEFINITIONS
[*]TEMP_VAR    UDATA
[*]temp        RES     1             ;example variable definition
[/LIST]
That little thing that said
temp RES 1
That means that you ask the compiler
to save a place called temp one byte after this
Code:
MAIN    CODE    0x000
You can now move anything you want to temp as long as it fits in the byte.
Like this
Code:
movlw   0x04              ; example code
Don't got be 0xFF they just used that cause it's easy
PICNewbee
Joined Mar 31, 2017
355
Burt
That is all good stuff you are saying.
Let me finish my first program and run it a few times.
Then we'll do variables.
I just want to declare one variable. Then write a value to it and look at it with IPE.
Yeah. Slow but sure.
PICNewbee
Joined Mar 31, 2017
355
Burt
Okay. There.
TEMP_VAR UDATA
You are saying that is the starting point. Good.
